S50 Reassembled.
  • hoveringuy
    • Dec 2005
    • 2715
    Originally posted by ck_taft325is
    The fucking MAF was on wrong. My dumbass was so tired last night that I just threw it on there without looking at the God Damn arrow ON the MAF.
    Have a coolant leak from what appears to be the thermostat, but, will report back after copious cleaning and checking and double checking shit.
    I've gotten so fatigued I could probably install the radiator backwards.
    • Danny
      • 14216
      Good job man!
      For the thermostat, I used only RTV on the housing, never had an issue.
      • ck_taft325is
        • Sep 2007
        • 6880
        She purrs like a kitten now. Just figured out the rear spring issue which is temporary until I can figure out a permanent solution. Bleeding the coolant, changing the oil/filter and zooming.
        Need a part? PM me.
        • ck_taft325is
          • Sep 2007
          • 6880
          Anyone have a clue where to look for ticking from the timing case/cylinder 1? Culprits, ect? Torque spec's on the timing guide tensioner on the side of the block?
          Need a part? PM me.
          • trackjunkie21
            • Jan 2010
            • 3962
            Vanos ticks when it needs replacing.
            Originally posted by Wh33lhop
            VANOS: sometimes you just need to go full retard.
            • ck_taft325is
              • Sep 2007
              • 6880
              VANOS has been completely rebuilt. Seals, O-Ring, ect.
              Need a part? PM me.
              • ck_taft325is
                • Sep 2007
                • 6880
                Any suggestions on bleeding the cooling system or am I relegated to sticking the nose in the air and squeezing a hose? Fuck I wish I had a bleed screw.
                Need a part? PM me.
                • Reckless_Havoc
                  • 156
                  This worked great for me. Squeezing the hose is the ticket!
                  • dude8383
                    • Jan 2005
                    • 10387
                    Why don't you just open the cap on the expansion tank and let it run for like 20min. That's how I bled my system.
                    My setup:
                    • ck_taft325is
                      • Sep 2007
                      • 6880
                      Well the issue is my top radiator to thermostat hose gets rock solid hard. And hot. The bottom hose from the block to bottom of radiator is next to dry. Thermostat stuck?
                      My setup:
                      By cap you mean the sensor plug or the actual cap? Tried it. Nadda.
                      Need a part? PM me.
                      • dude8383
                        • Jan 2005
                        • 10387
                        Nah the actual cap, drive around for like a half hour with the heat blasting. I've done this numerous times when bleeding this kind of system.
                        • Reckless_Havoc
                          • 156
                          I always put my car up on jacks, leave the cap off the expansion tank, heat on, then I usually pump the lower radiator hose. No idea if this is actually doing anything, but it has worked for me every time.
                          Good luck!
                          • ck_taft325is
                            • Sep 2007
                            • 6880
                            Well, here's the thing. I have heat coming from the heater, right now. The damn engine just isn't cooling. In the AM I'm bringing the car in the garage, getting it on stands, removing the radiator, flushing it, removing the thermostat and making sure everything's good and then attempting to bleed this bitch. God damnit I want an M42 radiator...
                            Need a part? PM me.
                            • Danny
                              • 14216
                              You just have to keep going. It took me a solid three tries until I felt comfortable.
                              • ck_taft325is
                                • Sep 2007
                                • 6880
                                Also, I'm not getting a temp reading on the gauge. Anyone happen to know the wire colors for the sensor that corrospondes with the temp gauge on a '94 M3 harness? Heh. Assuming I actually have a '94 M3 harness of course ;)
                                Need a part? PM me.
