You have a machine shop in your back yard to "properly" rebuild the top end including a shave of the head? What about the retainers ($90), the HG kit ($201)... ? Then you have Cams. Unless they are free... do you have cam locks already? What about the VANOS unit? It doesn't break the bank at $60 ($65.00 if you get the modified 18mm socket which you WILL need, ask me how I know...) but it's still a cost. Coolant, oil, assembly lube... You're already at $400 without the cams. So, throw S50 cams in there... $700 (if you get a screaming deal at $300). The cam locks, VANOS timing tool, cam installation/removal tool puts you at $1,100. Hrm. And you haven't even touched the thermostat, radiator, wire harness...
					M52 vs S50
 Need a part? PM me.
 So to you "properly" is to shave the head even if its perfectly flat? I am general mechanic maybe you never built any engines and only know what you read onlineYou have a machine shop in your back yard to "properly" rebuild the top end including a shave of the head?
 I am not talking about cost of the swap, you missed my argument! go back to post #17
 radiator, wire harness...Comment
 So you also have the tools to bore the block? Or just shorten the stroke with some new pistons or a different crank? (excuse me, as I haven't rebuilt an engine... but I know that displacement comes from SOMEWHERE)
 Plus the cost of rebuilding a head, which just with basic parts should be like 700 dollars in parts if you're going to do a decent job. That's no cams or anything.Originally posted by z31maniacI just hate everyone.
 No need for discretion.Comment
 No, I say take it to a machine shop to make sure it's flat. And if it's not, it will require a shave. To "properly" go about it, you pretty much need to. You have a pressure tester? What exactly do you have beyond a condescending, mildly ignorant attitude that you throw around a bit too much? You're making outlandish claims and calling everyone else stupid for not just "taking your word for it" because you've "done it before and will do it again".
  Need a part? PM me. Need a part? PM me.
 Get your Bass on. Luke's r3v Boxes are here: http://www.r3vlimited.com/board/showthread.php?t=198123Comment
 Well you're disqualified. Sorry. You're not a super general mechanic with years of experience... in your back yard.So you also have the tools to bore the block? Or just shorten the stroke with some new pistons or a different crank? (excuse me, as I haven't rebuilt an engine... but I know that displacement comes from SOMEWHERE)
 But, you nailed it with the costs. I just redid my top end on the S50.Need a part? PM me.
 I can't wait to read this writeup, so I can charge $2k to rebuild and modify 24v engines for $1k, all day long in my backyard. It's a shame none of the other engine builders, known worldwide, have been able to do this!Comment
 whaaaaaa 201 for a head gasket kit?!?! lol i love partially owning a shop and getting kits for 85-105 ;)sigpic
 ^Back in the game^
 BUILD THREAD: http://www.r3vlimited.com/board/showthread.php?t=201281
 FS thread:
 http://www.r3vlimited.com/board/showthread.php?t=214105Comment
 I haven't call anybody names, and you seem to get upset for nothing. I told you guys I am working on the write up and it will be done within two months, until then don't take my word.You're making outlandish claims and calling everyone else stupid for not just "taking your word for it"
 This is where you are wrong. If the head requires milling it is junk head, it was overheated and it is not worthy of using it for your project car.I say take it to a machine shop to make sure it's flat. And if it's not, it will require a shave. To "properly" go about it, you pretty much need to.Comment
 or just shave 20 thousants off and rais the hell out of compression and make sure u have good valve cutouts ;)sigpic
 ^Back in the game^
 FS thread:
 Hahahahahaahahahahahahahahahahahaha!             Need a part? PM me. Need a part? PM me.
 Jesus christ some of you guys really go out of your way just to prove to someone that they can't accomplish something. If you don't think he can do it then that his fucking problem people.
 No need to get all bent out of shape over this.IG: deniso_nsi Leave me feedback here
 Check Us out on Facebook
 Full Product Line Tuning
 OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
