first e30 w/ m50 swap IDLES ROUGH
  • e30rapidic
    • 2167
    #46
    Originally posted by nwe30
    im not sure how to check the fuel filter. where is this?
    im not sure how many miles are on it. the previous owner had an m50 engine swap and the engine has 68k on it.
    the big silver cylinder....drivers side, in front of rear wheel
    '87 325ic, powered by S50.
    • farix
      • Jun 2010
      • 54
      #47
      I can hear a vacuum leak in the last video. Look for the source of the hissing noise. Also you can rule out fuel issue by renting a fuel pressure gauge. I think something fell off when you and your sister were pounding it around town.
      • blackhawkimpact
        • 2415
        #48
        You still have a vacuum leak. Check everything is tight. I had the same Idling issue and turned out that my master cylinder was missing a bolt and that's where the leak was
        • trackjunkie21
          • Jan 2010
          • 3962
          #49
          That's a big vacuum leak, I hear the hissing.
          Originally posted by Wh33lhop
          VANOS: sometimes you just need to go full retard.
          • BlapBlap
            • 564
            #50
            My e36 just started doing the same thing yesterday right before i had to go to work. Left my car at my house then opened the hood with morning and turns out it was a vacuum leak....it was the "plug in hose" on the underside of my intake manifold right on the other side of the throttle body
            • nwe30
              • Feb 2011
              • 385
              #51
              so i have a family friend who owns a shop and his shop is called "japanese auto" but he told me to get it towed over to his place so he could check it out. he looked it over and told me he could not find a leak....but i wouldn't trust a mechanic who specializes in asian cars...so i don't know what to do. he said he'd take the ICV out tomorrow and see if he finds anything. he tried hooking up a diagnostic computer to my car but for some reason it wouldn't read right. he said his computer reads from 1992+ and my engine is an m50 out of a 1992 325i...so i don't know.
              he said he'd look over the bmw manual and look at it with his assistant sometime tomorrow. hopefully they get this straightened out...i haven't had a car in the longest time and i've been borrowing my mother's car and she has been losing patience !
              it seems that everybody is saying its a vacuum leak...is it for sure a vacuum leak? so then i could go drop by tomorrow and let them know its a vacuum leak and ask them to hoist the car up and look from underneath or something, idk
              • nwe30
                • Feb 2011
                • 385
                #52
                spark plugs are also almost out ...so i ordered some NGK BKR6EK plugs on ebay.
                http://cgi.ebay.com/ebaymotors/ws/eB...#ht_1589wt_854
                • 416stroker
                  • May 2008
                  • 2448
                  #53
                  I dont think its a vacuum leak.
                  OP Pm Sent
                  84 318I Delphin RIP
                  87 325IS delphin 24v Sold
                  89 325 Alpineweiss
                  • nwe30
                    • Feb 2011
                    • 385
                    #54
                    so i dropped by the shop today after school and my mechanic said the ICV is bad. he plugged some electronic tool type thing (sorry, i don't know much) and he said the spring inside won't respond. he brought out an ICV that he pulled from a volvo and did the same thing with the whol electronic tool thing and the ICV made clicking sounds from inside (almost as if there was a spring in there pushing a bolt) whereas the ICV pulled from my car didn't respond or make any type of clicking sounds at all....
                    so now i'm in need of a new ICV $$$ let's hope this is the REAL problem.
                    • 416stroker
                      • May 2008
                      • 2448
                      #55
                      s
                      Should be. But get on the ckeck engine light.
                      you would have other symptoms of it was a vacuume leak.
                      84 318I Delphin RIP
                      89 325 Alpineweiss
                      • nwe30
                        • Feb 2011
                        • 385
                        #56
                        i don't get what you mean by "the check engine light doesn't work"
                        i'm looking at the video and its there!
                        • ck_taft325is
                          • Sep 2007
                          • 6880
                          #57
                          It's not. Your "Check" light is working.
                          Greg doesn't do "Check Engine Lights" wired in. He fucking wires them into the wire harness plastic bit that goes over the top of the engine because he's too fucking lazy to do it right. You should wire that in. When I get ready to do mine (read: have time) I'll gladly do yours once you can get to my place.
                          Again, sorry for not being able to make it down that night, bud. Parker's shop isn't that far at all from you and you're more than welcome to stop by and turn some wrenches some time. Learn etc... I'll be around there in the coming few weeks.
                          Need a part? PM me.
                          • nwe30
                            • Feb 2011
                            • 385
                            #58
                            it's all good Chris! but damn....really? i had a feeling that greg might've done something different..
                            i will definitely drop by once my car gets rolling along. just let me know when you're going to Parker's please!
                            meanwhile....i need to find a nice ICV to pop into my car, do you have an extra by any chance?
                            • Killacortes
                              • 1937
                              #59
                              the fuel filter should be good. i replaced that not too long ago. should have like 3k on it
                              r3v does not fuck around. First you get banned, then they shoot you
                              • nwe30
                                • Feb 2011
                                • 385
                                #60
                                416stroker, car is still not fixed yet...
                                replaced the icv and it's not as bad as it was before, but it's still not right. once i get the car going, i'll definitely ask you to help me out with the wiring
