Another brake booster question
    What are the actual dimensions of the A4 booster/MC combo? Diameter of the booster and total distance from the firewall to the MC.
      1st page for audi info.
      Originally posted by Roysneon
      $5 shipped?
      Originally posted by MarkD
      You are a strange dude, I'n not answering any more posts from you.
        I'm going with an S54, as it isn't listed, I still have the questions about the actual dimensions. It likely isn't going to work, but I at least have to ask. I'm currently on the list to receive Lee's boosterless set up.
          I have the E21 booster because I needed a new booster anyway. I just found the lowest price I could find for a reman unit, and modified the shaft. I went a different route though, I drilled out the nut and clevice to M12 instead of trying to cut the shaft down the M10. Took half an hour tops with a drill press and a tap and die set, brakes feel fine! The pedal is a little stiffer but I'm not worried about being able to stop.
            I need to swap out my Ix booster.
            What booster has the best pedal feel?
              I've got his booster delete kit on the way as well.. I cannot wait to fire the S54 up with open headers in the garage. My neighbors will remember why they hate me.
                I stock these setups for cust cars:
                Check Us out on Facebook
                Full Product Line Tuning
                  booster
                  I run a 944 booster on my s50 swapped car.....its a track car thats driven to tracks.
                  I love it..on the firm side.....but barely noticeable over stock set up....IMO
                  40 bucks...win
                    My swap car has the 7 series booster/e34 master and it is awesome, pretty firm. Total cost was less than $30.
                    Looking for a clean e30 shell for a project.
                        I modified the rod on my 944 booster and installed today. Hopefully the motor will be going in tomorrow or Monday. Harbor Freight die set worked like a champ.
                        I removed the drivers seat for easier access, more comfortable to do laying on back with feet in the rear seat. haha. Must be a real pain in the ass to get to the bolts for those who have just slotted the firewall to move the stock booster over.
                        '87 325ic, powered by S50.
                          Swiss does NOT approve. :hitler:
                          Originally posted by 325Projectz
                          don't listen to the diagram... listen to mr. swiss.
                          :nice:
                            I didn't find it difficult at all and I left my seat in.
                              quick question: for those who just shifted stock booster over, how did you get the 4th nut on next to the bracket? i have the top right bolt (from the inside) pinned right up against that bracket so there's no way to get that bolt on. is it ok to use just 3 bolts?
                              Thanks
                                Thanks
                                Im just using the three. I figured if it ever seemed to start to flex, I would switch boosters then.
