Deciding on chip for m50 w/ s50 cams
  • BlapBlap
    • 564
    Long story short I got ripped off by some kid named joey that got banned from here awhile ago. Anyways turns out the car i bought didnt have a dme or the tms chip that he said it did. Now im looking for a chip to buy and was leaning towards getting a miller war chip.
    Just wanted to get your guys opinion on what kind of chip to get or if anybody is running a war chip in their e30...
  • dude8383
    • Jan 2005
    • 10387
    TRM makes great stuff :)
    • e30rapidic
      • 2167
      I just ordered a TRM chip for my S50
      '87 325ic, powered by S50.
      • JGood
        • Jan 2004
        • 7959
        I'd recommend TRM.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • ///Maddog9000
          • Apr 2009
          • 157
          TRM makes a good product but, since you don't live in Atlanta or anywhere remotely close, you are stuck with a 'off the shelf tune.' Sure they will spec it for your mods and a dyno sheet will help but, it's not as custom as you would like. It will run the car and it will run well but, its only as good as a remote tune can be.
          I'd say go for a Miller chip. Take it to the dyno and tune it yourself.
          I'm currently building a m30b34 turbo with Miller Chip and MAF setup.
          '08 328i Sedan -daily touring car
          '89 335i Coupe -parting out
          '01 330i Sedan -divorced
          '90 325i Coupe -smashed
          e30m50tu@gmail.com
          • JGood
            • Jan 2004
            • 7959
            Guess it depends what you want to spend and how crucial every last HP is to you. Just the dyno time to create a tune that's better then a TRM off-the-shelf tune (or any name brand tune for that matter) will probably far exceed the cost of the TRM tune. Especially if you're not familiar with tuning.
            Obviously, going with a turbo build like yours, you can probably get a good bit more power with a custom tune. m50's with s50 cams aren't exactly powerhouses, so you're probably only looking at a few HP gain for a good bit more money...
            • e30polak
              • 6136
              It's just an M50 with S50 cams, not much room for improvement from a solid off the shelf tune... :roll:
              You have a completely different situation since you're doing a custom turbo set-up, where a dyno tune is critical to making power and improving reliability.
              INSTAGRAM: @UNDR8D_EMPIRE
              • ///Maddog9000
                • Apr 2009
                • 157
                You guys are definitely right about a fully tune-able setup being over kill on a m50 w/ s50 cams. You are also right about it not being a powerhouse. I was very unsatisfied with my m50tub25. TRM will re-write tunes for as long as you own it. If you can tune a WAR setup yourself then it's actually comparable in cost. I think a TRM remote tune is $650. If their 'off the self' tune supports you mods, that's a winner at $250. A WAR Chip is $350 and dyno tuning is usually around $100 an hour. By that math, you have three hours dyno time to get your setup down.
                I'm waiting for Matt and Brody to start chiming in...
                e30m50tu@gmail.com
                • e30polak
                  • 6136
                  Matt may chime in, but Brody doesn't spend much time on here. ;)
                  As far as you not being satisfied with the M50, it's because it never saw any boost. :nice:
                  • matt
                    • 3732
                    I am a new-found follower of the golden rule, so I will just say that I really appreciate you guys supporting us. :)
                      • 34847
                      I know exactly what you are thinking.
                      • BlapBlap
                        • 564
                        So it seems like everyone likes the trm chip but I know a guy that use to work for miller performance and im gunna see if he can help me out with the tune if i get the war chip...might go turbo later down the road.
                        • matt
                          • 3732
                          If you buy a TRM NA chip, you will get 100% credit for it when you upgrade to a turbo tune package.
