Larger throttle bodys? worth it?
  • Bennetts22@aol.com
    • Jun 2006
    • 171
    I have a S52 obd1 that i have pretty much every bolt on already. is a larger throttle body/ silicone intake hose worth it? whats a good one? several company's sell them from vac 399.00 to treehouse 700.00. has anyone tried any of these and was there any gains?
    TIA Brandon
  • hoveringuy
    • Dec 2005
    • 2735
    It will make a very small difference.
    On the M54 I went from the M50 TB to a larger M54 sized one, flow area was around 15% greater but I saw 0 gains on the dyno with some small decrease in perceived driveability at lower rpms.
    S52 has a better head so I think you would see more than zero but i don't think it would be much more.
    • 328ijunkie
      • May 2007
      • 3961
      S52 head>M54? ORLY?
      Check Us out on Facebook
      Full Product Line Tuning
        • 34844
        there is a relatively simple way to measure if you need a larger TB or not. You need a MAP sensor/vac gauge hooked into the intake manifold. Read ambient atmospheric pressure (depending on where you live, it will be 101-80kpa). read pressure at WOT. if WOT pressure is significantly lower than ambient, your throttle is causing a pressure drop. if they are the same, then upgrading the throttle will do nothing.
        • hoveringuy
          • Dec 2005
          • 2735
          Originally posted by 328ijunkie
          S52 head>M54? ORLY?
          Yep, the exhaust ports on the M54 are restrictive. S52 definately flows better (although the M54 dual VANOS is better)
          Brady went from a 67.5mm TB to 72.1mm on a cammed motor with headers over at e46fanatics. His results were mostly inconclusive and at best he gained 3hp.
          Concur. I used the standard GM MAP sensor that I got for like $5. It ouputs a 0-5V signal that integrates easily with my datalogger.
          • e30rapidic
            • 2167
            wait a tick...aren't the heads the same casting number???
            '87 325ic, powered by S50.
            • hoveringuy
              • Dec 2005
              • 2735
              M52 and S52 are, but M54 is way, way different.
              • e30rapidic
                • 2167
                too much calculus studying. the M5FOUR part didn't register.
