Need help m50 NV 92, crank no start
  • Matt-B
    The Waffler
    • 3856
    Motor is cranking and not starting
    I have fuel to the front of the rail, the spark is mad crazy, so I think my injectors are not opening?
    I cleaned ground at end of rail and reinstalled, popped 1 time, then nothing.
    Jumping it from another car, did nothing, so tomorrow Im going to swap ECU's and MAF...
    ECU was from a running car, but MAF, I am not sure....
    opinions, thoughts, questions?
    thanks
    ps: Im also going to switch cam, and crank plugs...would things like ECU, MAF, and Crank Sensor, make injectors not open?
  • ahriley91
    • Jan 2010
    • 451
    Before you go buy some more parts, try switching the fuel lines. If might not work, but it's worth a shot.
    http://www.r3vlimited.com/board/showthread.php?t=162444
    • Matt-B
      The Waffler
      • 3856
      front fuel line, i popped off, into bottle, filled bottle, its the right line
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        It will run like shit with a bad MAF. That means it will run.
        Take off an injector connector, grab two pieces of wire and a flashlight bulb, make a ghetto test light and see if the injectors are getting pulse.
        • Matt-B
          The Waffler
          • 3856
          doing that tomorrow yea, thanks Farbin
          • e30s50dan
            • Nov 2008
            • 2076
            Spray a little starting fluid in the intake...behind the maf. If it try's to start,chase the fuel issues
            NASA
            BMWCCA member
            PCA member 25yrs
            1991 318IS slick top
            1997 M3 sedan
            2001 325CI DD
            “whoever turns the wheel the least, wins"
            • dirty30
              • 3010
              is your dme grounded?
              are your cam and crank sensors on the wrong engine harness plugs?
              • Matt-B
                The Waffler
                • 3856
                I heard, the DME does not need a ground, its grounded through harness, and Ill switch CAM and CRANK here shortly
                • Farbin Kaiber
                  Lil' Puppet
                  • 29502
                  lol.
                  • Matt-B
                    The Waffler
                    • 3856
                    put a ground on DME to strut tower, going to make a better ground here shorty, didnt not make a difference, going to buy a fuel pressure gauge soon
                    FML, why cant a swap go off with out a hitch, everything is from a running car
                    • Jand3rson
                      • 37587
                      It doesn't matter if it's from a running car. You've got something hooked up wrong/backwards/not at all somewhere. Just have to find it.
                      • samiam3356
                        • Jul 2009
                        • 1901
                        Resistance on the cps should be in the low 500's. Check that. Large vac leak?dme is grounded on the shock tower btw.
                        Originally posted by Roysneon
                        $5 shipped?
                        Originally posted by MarkD
                        You are a strange dude, I'n not answering any more posts from you.
                        • Matt-B
                          The Waffler
                          • 3856
                          it was ground down below by motor ground, i can ground on strut tower, its wanting to start, new plugs, getting spark, getting fuel, going to test fuel pressure here shortly...
                          if my FP, is not high enough, could that be a FPR or pump? pump is about a year old, FPR was on running car when motor came out
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            I don't think it's the pump. Or the FPR. I think something is still plugged in the wrong connector. Check the Wiring Diagram for the harness you have, and make sure each connector is where it's supposed to be. There are only a few you could mess up.
                            • e30s52
                              • Oct 2007
                              • 5235
                              Have you checked the CPS yet?
                              www.gutenparts.com
