no fuel no spark
  • jrdeamicis
    • Nov 2008
    • 956
    So I am back on the Job. So do you have fuel pressure or does the pump just prime? You need to check that. If the pump is giving 40/50PSI while cranking its turning on the pump. (It only turns on while cranking).
    Can you give me your wiring chart for your adapter. I want to check it.
    Past Car : E30 S50 6 Speed 5 Lug 3.73
    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
    ___________________________________________
    BNB Designs
    Engine Swaps, Fabrication, Innovation, General Repair
    Richmond CA
    Julian 848-248-8029
    • rotarievtec
      • Jul 2010
      • 261
      My pinout
      c101
      1 alt
      2 oil level static
      4 coolant temp
      5 oil pressure
      6 02
      7 ign switch
      8 fuel economy gauge
      9 tach
      10dynamic oil level
      11 si reset
      12 cel
      13 fuel pump relay
      14 speed signal output
      15 starter
      16 diag connector
      18 ign 12v
      x20
      2 dynamic oil level
      8 cel
      12coolant temp
      13 fuel pump relay
      14 speedo signal
      15 starter
      16 static oil level
      18 ign
      19 diag connector
      20 engine speed
      21 ign
      22 os
      23 oil pressure
      24 feul econo gauge
      25 alternator
      c101-x20
      1-25
      2-16
      4-12
      5-23
      6-22
      7-21
      8-24
      9-20
      10-2
      12-8
      13-13
      14-14
      15-15
      16-19
      18-18
      Originally posted by NitroRustlerDriver
      I don silk gloves and place them into a sacred envelope made of magic and lined with Unicorn fur, seal the envelope with an adhesive made from strands of Gypsy hair and wrap the whole thing in a snazzy looking faux gold leaf paper, with elm leaf inlay from Costco. Unfortunately, by the time it gets to you, all of that fancy stuff will likely have been picked clean by the greedy postal service employees. Please don't be surprised to see just a plain envelope.
      • jrdeamicis
        • Nov 2008
        • 956
        Check these pins for +12V
        56
        27
        26
        54
        So wait, is your cam sensor a 3 wire or a 2 wire? The wiring diagram that I have for the non-vanos 525i engine says both are a VR sensor.
        So pins 16+44 should be cam shaft sensor, look for milivolts while cranking. Also check your PN of the cam sensor and make sure you have the right one for your engine.
        BNB Designs
        Richmond CA
        Julian 848-248-8029
        • rotarievtec
          • Jul 2010
          • 261
          Both my cam and crank are 3 wires and i dont have any spare 2 wire connectors on my harness. I will probe those wires when i get home. Do i probe 56 27 26 54 when cranking or just in run position?
          • jrdeamicis
            • Nov 2008
            • 956
            Yes.
            Do you have a wire in pin 42?
            BNB Designs
            Richmond CA
            Julian 848-248-8029
            • rotarievtec
              • Jul 2010
              • 261
              Ill have to check when i get home. Is it cool if i give you a call again after i check all that stuff out?
              • jrdeamicis
                • Nov 2008
                • 956
                Meter between pin 3 on both the cam and crank. You should see continuity. And I mean meter Pin 3 and Pin 3 @ the same time
                BNB Designs
                Richmond CA
                Julian 848-248-8029
                • jrdeamicis
                  • Nov 2008
                  • 956
                  Do you have a pin 10 in your x20?
                  Or a 65 in x6000?
                  BNB Designs
                  Richmond CA
                  Julian 848-248-8029
                  • rotarievtec
                    • Jul 2010
                    • 261
                    will do. Ill get back to you in a few hours with my results
                    • rotarievtec
                      • Jul 2010
                      • 261
                      I do not have a pin 10 on my x20
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        Yes, I am just posting my questions so you can answer them later. Yes, You can call me and see if I am able to talk.
                        Are you using the same trigger wheel for a non-vanos? On the front timing cover.
                        BNB Designs
                        Richmond CA
                        Julian 848-248-8029
                        • rotarievtec
                          • Jul 2010
                          • 261
                          Thats kinda what i figured, this definantely give me a place to start. Yes same trigger wheel. I havent taken anything off the engine except for the a/c compressor and corresponding pulley on the crank. Trigger wheel never came off, not saying that the p.o. didnt do something funky.
                          • Matt-B
                            The Waffler
                            • 3856
                            tried switching cam and crank plugs? maybe there backwards?
                            • rotarievtec
                              • Jul 2010
                              • 261
                              Ya already switched those too everything seems right but no spark.
                              • jrdeamicis
                                • Nov 2008
                                • 956
                                Engine Computer
                                BMW 325 i 0261-200-402,,,1748401-003-078 100409 $50 Flamingo Auto USA-FL(Homestead) E-mail 305-245-6183 956
                                BNB Designs
                                Richmond CA
                                Julian 848-248-8029
