Hey Guys,
So Ive searched my eyes sore and now I need your help.
I have an s50 swapped into my E30 and its been running like a champ for a few months now. The motor is basically stock with a lightweight flywheel, Dinan BBTB, rebuilt head with updated lifters, raceland headers. I track it often and just did a upgrade to Euro 3.5 HFM, 21# injectors, and TRM tune with bimmerworld boot 2 days ago.
SO yesterday, I am driving regularly as the engine is warming up and its starts to misfire.
It misfires during idle and while under load, down on power. The idle is steady and is not erratic at all. No smoke coming out of the exhaust, or anything odd in the coolant. No temperature problems. No fault codes.
I immediately thought that maybe the injectors went bad since I bought them used so I bought new injectors, installed them...still same problem. I changed the plugs, still same problem. And the same result after I cleaned the MAF. I am now going to play with different OEM coil packs tomorrow and I hope just like the other times that it may fix the problem. Sounds like the misfiring is most audible around cylinder 5 and 6.
Now I need to ask you experts. Could I have somehow damaged a valve on track (I hope not)? It drove fine the whole track day, the 2hr trip home, and for 2 days after. What else could it be?
Cliffs:
-I have an s50 swapped e30 that I track often
-I developed a misfire 2 days after I upgraded to Euro hfm, 21# injectors, and TRM tune
-Misfires during idle and under load
-sounds like a go kart now and is down on power
-Sounds like the misfiring is most audible around cylinder 5 and 6.
-Idles perfectly, no temp issues, no smoke, coolant looks fine, no fault codes
-I changed to brand new injectors, spark plugs, and cleaned MAF
-Going to play with different coil packs soon
-Need your input
Thanks guys
Cliffs:
-Need your input
Thanks guys
