m20 flywheel hitting e34 oil pan
  • luis.e30325es
    • Feb 2011
    • 128
    can anyone help me out?
    engine is in, i don't mind taking it out as i already have to secure that reversed threaded nut for the oil pump.
    i just need to know how much it needs to be shaved from the back side of it to fit properly with the pan.
    any specifics?
  • StereoInstaller1
    GAS
    • 22679
    Flush with the teeth is standard
    Closing SOON!
    Thanks for 10 years of fun!
    • Jand3rson
      • 37587
      I had them take mine down to about 1-2mm above the ring gear.
      • StereoInstaller1
        GAS
        • 22679
        That is the pic I am showing my machinist
        Closing SOON!
        • sticksdaman
          • Apr 2005
          • 2987
          noob question, but how much did it run you, did they lighten yours as well aside from the shave?
          @Janderson
          Originally posted by ebelements
          Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
          • Adrian_Visser
            • Jun 2006
            • 2823
            Umm shaving all that metal off is lightening it?
            '89 Alpine S52 with goodies
            • Jand3rson
              • 37587
              @Janderson
              Adrian is right, just that amount they took off did lighten the flywheel by about 3-4 lbs, which is a lot. A lot of people will have a large portion of the mass from the center out toward the edge of where I had the flywheel milled out too, taking out another substantial chunk of weight, but the shop I took it to wasn't really able to do it with their setup, and I didn't want to go searching all over for a shop that could. That degree of lightening is really unnecessary, anyway.
              To have that material removed as well as a resurfacing (make sure you do that), cost me about $85, which is a little high, but not outrageous.
              • 328ijunkie
                • May 2007
                • 3961
                Picture ninja stolen for future reference ;)
                Check Us out on Facebook
                Full Product Line Tuning
                • Jand3rson
                  • 37587
                  Please do, that's why I posted it!
                  • StereoInstaller1
                    GAS
                    • 22679
                    changing lives one pic at a time
                    Closing SOON!
                    • sticksdaman
                      • Apr 2005
                      • 2987
                      I meant to say resurface but my hands typed shave, brain fart.
                      Thanks for the reply, I was just gauging how much $ I should allot for that when the time comes (aka right now).
                      • z31maniac
                        • 17566
                        I told the clutch shop to make it 12lbs, they did, it fit.
                        And with Redline MTL in the trans, I had no "rattle" from the lightweight flywheel, and an S52 still provided plenty of torque to get away from a light.
                        www.gutenparts.com
                        • dreamchasin
                          • 3892
                          When I did my swap using the G260, I had a local shop shave my flywheel like yours, but all the way down to the gears. Completely smooth around it, cost me $40 bucks. No rattle/vibration from it or anything.
                          90 325is alpine2 m50b25 becoming a dorifto car.
                          • highoutput
                            • Apr 2011
                            • 94
                            I threw mine on the brake leathe, and just kept cutting. Worked out great.
                            I also have an extra I'm selling, thats been cut down in back and resurfaced in front, if anyone needs one.
                            24V M50, M3 cams, Turner Tune, full exhaust, ect....
                            • luis.e30325es
                              • Feb 2011
                              • 128
                              I am definitely going to show that picture to my machinist.
                              thanks for the help guys, greatly appreciated.
