m20 flywheel hitting e34 oil pan
  • luis.e30325es
    • Feb 2011
    • 128
    Adrian is right, just that amount they took off did lighten the flywheel by about 3-4 lbs, which is a lot. A lot of people will have a large portion of the mass from the center out toward the edge of where I had the flywheel milled out too, taking out another substantial chunk of weight, but the shop I took it to wasn't really able to do it with their setup, and I didn't want to go searching all over for a shop that could. That degree of lightening is really unnecessary, anyway.
    To have that material removed as well as a resurfacing (make sure you do that), cost me about $85, which is a little high, but not outrageous.
    Yeah i'm just going to take it back to where they resurfaced the other side.
    it cost about 35 bucks for resurfacing, which isn't bad being that they do commercial trucks with big flywheels.
    i wonder how much they will charge me for this.
    thanks for the help
    • luis.e30325es
      • Feb 2011
      • 128
      I had them take mine down to about 1-2mm above the ring gear.
      i dont know if its me or just the pic, but did they shave around the center by the holes for the bolts?
      • luis.e30325es
        • Feb 2011
        • 128
        got mine to look exactly like that. cost $28 which isn't bad.
