Official Electric Fan wiring thread!
  • SHunter
    • Dec 2010
    • 154
    #61
    Well, that makes sense. These cars definitely have a weakness in the cooling system and I guess the 80C can buy you some time when things go haywire.
    I'm still gonna stick with the factory setup for now since my entire cooling system is new, I don't have AC, and I live in a pretty cool environment. Hoping that big 'ol fan I just bought keeps the temps rock steady.
    -Steven
    • 328ijunkie
      • May 2007
      • 3961
      #62
      If you're running no clutch fan you have to get a Lower temp switch like a 88-98 as the stock one is designed around a clutch fan being thete
      Check Us out on Facebook
      Full Product Line Tuning
      • BoostinEuros
        • 363
        #63
        Are there any alternatives to the temp switch you linked? They seem to be out of stock everywhere I check (Pelican, RMeuropean)
        '91 "318is" slick top M50 turbo
        '97 Dodge 3500 12v Cummins
        '12 Mini Cooper S
        '89 318i Chump Car Project
        • eurosport22
          • 210
          #64
          bump with boostineuros. i cant find one place that has them in stock
          • bstarr3
            • 170
            #65
            Sorry for the dumb question, but what additional wiring, relays, connectors etc do I need to wire a fan exactly as described in post #1? I know nothing about wiring, automotive or otherwise. Am I running wires from the temp switch and from the aux fan harness into the new fan? My new fan only has two wires and a plug connector. Thanks fit helping a noob
            Sent from my DROID RAZR using Tapatalk 2
            • NERDE30
              • Oct 2009
              • 133
              #66
              I got a question for you guys . I can not seem to figure out which 80deg thermostat to us with my S50 . Can anyone point me in the right direction ?
              • Lithium
                • Mar 2012
                • 88
                #67
                Sweet!!!!!
                I just hooked up the 82 Deg fan switch that I got from http://www.bimmerspecialist.com - It was under 10 Bucks - I connected the two wires from the high speed and that was it - It works perfectly - Comes on when it hits 82 exactly and only runs for about 30-45 seconds and the motor cools right down.
                Great Mod - Great Thread - Most helpful > THANKS!!!!
                PS: I am using the stock fan with AC deleted.
                I Love my Bimmer. :up:
                http://www.r3vlimited.com/board/showthread.php?t=316184
                • Fusion
                  • Nov 2009
                  • 3659
                  #68
                  Guys, if the two top wires on the °o° radiator switch get flipped, will the fan speed be fast then slow?
                  I ask because I had to fix the wires there that broke off and now I think I heard the fast speed come on first, which leads me to think I might have flipped them. They were both yellow, iirc, one y/brown, the other y/purple.
                  • singh336
                    • Dec 2010
                    • 211
                    #69
                    What aux fan is best to use for space / CFM , i don't care about noise really, just want something for a good price.
                    I searched for the fan switch you for, found it for 8.99, should I be searching for that under my E30, or for an E36/E34 for the M50 motor?
                    Where does this thread into and does it directly fit or need to be rethreaded because I thought one of these temp sensors needed to be rethreaded?
                    • Lithium
                      • Mar 2012
                      • 88
                      #70
                      82 deg fan switch is from a 1984 318i - it screws right into the rad no worries.
                      I am using the stock fan - there are allot of aftermarket options & opinions to match - but for 33$ Ireland Engineering has a 14" fan that should do the job.
                      PM me if you need any more info.
                      ChrZ!
                      • singh336
                        • Dec 2010
                        • 211
                        #71
                        awesome, thanks!
                        • eurosport22
                          • 210
                          #72
                          i hooked mine up so that high speed is the one that always comes on. i also used the 82 degree fan switch.
                          http://www.rmeuropean.com/Part-Numbe..._10832E0B.aspx
                          i dont know where my resistor went but if it doesnt run very long then it shouldnt make a difference. i used a spal 16" pusher wired up like in the first page and it works perfect. the only thing is i had a factory 15amp fuse in the box so when i hit the switch it poped right away. threw a 30 amp in there and boom. perfect.
                          http://thmotorsports.com/spal/spal_f.../i-520006.aspx
                          its a little pricey but it moves over 2,000 cfm's and its gets to the mid to high 90's here in md over the summer so i figured id be safer than sorry
                          • 328ijunkie
                            • May 2007
                            • 3961
                            #73
                            Glad to see people still mostly referencing this thread vs making new ones lol. ;)
                            • 36brua
                              • 689
                              #74
                              I always just utilize high speed and use this switch: (61-31-1-364-272..
                              ok I give up. Where is this switch is installed ? replaces temp switch in side of radiator? and if in radiator my connector is 3pin 89 E30
                              thank you
                              My CA legal M60 swap
                              The happening in our garage
                              • 325e10
                                • 161
                                #75
                                thank you
                                yes replace the 3 pin switch with the 2 pin switch.
