OK I just installed the IE 14 inch electric fan as a pusher. I don't have AC so the fan fits in the AC/Aux fan spot nicely. I have the 82C fan switch in the radiator and all wired up to the original wiring. My problem is that the coolant temp gets above the half way mark and the fan doesn't kick on. If I jumper the switch the fan comes on and everything is good to go. So, bad switch? Actually I have two of the same switches and nothing happens with either. Two bad switches? One is brand new. I guess I should test the switch in 82c water.
Any ideas?
Gus
Any ideas?
Gus
