exhaust question
  • BADCLOWN
    • 399
    exhaust question
    whats the general consensus on running either dual 2.5 front to back vs. running a 2 into 1 pipe with a single 2.5 front to back?
    my m52 project is currently still in its building phase and ill be running OBX m52 headers (if that even matters)
    FOR SALE: diamantschwarz metallic 1991 m52 e30
    silbergrau metallic 2004 330i ZHP
  • ACHTUNG
    • May 2005
    • 2397
    I'm no exhaust guru but from all the research that I've done I found that if you're under 300hp a single 2.5" from the headers is fine.
    1989 US E30 Cammed S52
    Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
    • e30polak
      • 6136
      If you go dual, I wouldn't run larger than dual 2.25". If you want to go single, you will be fine with single 2.5".
      INSTAGRAM: @UNDR8D_EMPIRE
      • BADCLOWN
        • 399
        would i be better off buying a prefabricated exhaust (superspring, etc) for my e30 in 2.25-2.5 diameter than going custom and buying a muffler?
        looking for a more cost effective alternative without going SUPER cheap and still having some quality.
        • giantkeeper
          • Aug 2009
          • 1416
          I paid like $600 for my custom pieced exhaust single 2.5 from the headers back. Vibrant makes nice resonators and mufflers.
          Always Always go for the reach around if there is an option
          • EduardoGomez
            • Feb 2011
            • 48
            Only a heavily tattooed fool who tortures wild snakes would pay that much for exhaust.
            • luis.e30325es
              • Feb 2011
              • 128
              wtf really man?
              • Jalves619
                • 596
                Hahahahahhahahahahhahahahahhahahahahhahahahhhhhhhh hhhhhhhhhahahahahahahahhahahahahahahahahahahahahah hahahahahahhaha...
                Oh sorry I need to catch my breath, excuse me
                Hahahahahhahahahahhahahahahhahahahahhahahahhhhhhhh hhhhhhhhhahahahahahahahhahahahahahahahahahahahahah hahahahahahhahahahahahhahahahahahhahahahhahahahaha hahahha
                • giantkeeper
                  • Aug 2009
                  • 1416
                  I approve of this message
                  • z31maniac
                    • 17566
                    There has to be a shop in your local area that is known for doing custom exhaust work. Find one that will build you an exhaust with "mandrel bent" tubing vs "Crush bent."
                    Even if they are just cutting the sections you need out of mandrel pieces.
                    Get your muffler/cat/resonator or whatever together, go in and tell them what you want.
                    I'd go single 2.5" for a cost/simplicity issue, the slick thing to do is add a V-band clamp up front so the exhaust is super easy to drop and get out of the way for future maintenance.
                    If you have any forced induction plans, then I'd go ahead and just go 3"
                    My two cents.
                    www.gutenparts.com
                      • 34844
                      crush bends aren't bad if they're done properly (up to 30 degrees or something? it's on gustave's website).
                      You have to be careful with mandrel bends that are peiced together, because if the guy does a sloppy job of welding (with ridges/steps inside the pipe) it's going to be worse than a good crush bend and cost more at the same time.
                      if you're staying N/A I'd go for a single 2.5". Vbands are nice, just make sure your welder knows WTF he's doing, if he warps the vband flanges they won't seal properly. Otherwise they make it super easy to remove the exhaust, we're talking under 5 minutes rather than a half hour or more (stupid rusty 3-bolt flanges!).
                      EduardoGomez - dude, you're sort of walking on thin ice here. did you come in just to insult a guy because he had a decent exhaust system built? WTF? $600 isn't even that much.
                      • hoveringuy
                        • Dec 2005
                        • 2751
                        I built this to Nando's specs and have been very happy with it.
                        • Jalves619
                          • 596
                          Somewhat on topic. Is a 3in single exhaust going to noticeably decrease torque on a NA s50? I'm considering adding a turbo in the future, once my bank account recovers a bit from the swap, and it would be nice to not have to redo the full exhaust.
                            • 34844
                            not if you have good headers; torque is made in your headers not the exhaust pipes.
                            • Adrian_Visser
                              • Jun 2006
                              • 2823
                              Are you kidding me? You can't even get a good set of headers for $600.
                              I love how people expect exhaust work to be like $300 for tubing and mufflers and labour.
                              You make me laugh. Go look at how much a decent muffler, cat and resonator cost, then multiply by two if you want dual piping.
                              '89 Alpine S52 with goodies
