Any interest in plug and play gauge temp senders?
  • 328ijunkie
    • May 2007
    • 3961
    If youre using a 2 port OBD2 head youll be interested in this:
    Redied to M12:
    Pricing depends on interest. Will be using brand new sensors.
    Check Us out on Facebook
    Full Product Line Tuning
  • I*Do*Werke
    • Dec 2010
    • 259
    I will buy one of those from you right now. Im sure plenty of other people will too
    ^M52B28^
    • StereoInstaller1
      GAS
      • 22679
      So this still means drill and tap head, correct?
      Closing SOON!
      Thanks for 10 years of fun!
      • 328ijunkie
        • May 2007
        • 3961
        No. The sensor threads directly into the head. You remove the TB heater line port and install this. "Plug and Play!" ;)
        • samiam3356
          • Jul 2009
          • 1901
          He's grinding down the sensor and rethreading it. Nothing new just making it simple for people that can't do it. I did my own on my swap and it isn't that hard. Unfortunately you break(edit motherfuckers muahaha) it and you buy a new one.
          Originally posted by Roysneon
          $5 shipped?
          Originally posted by MarkD
          You are a strange dude, I'n not answering any more posts from you.
          • 328ijunkie
            • May 2007
            • 3961
            What you mean you brake it? lol
            • 10Toes
              Me Father Was A Tree
              • Jan 2008
              • 61222
              He means if the person is grinding one and rethreading it themselves and mess it up then they have to buy a new one. With buying yours it takes away that risk.
                • 34844
                brake/break....
                how many here failed english 101? lol :)
                • 328ijunkie
                  • May 2007
                  • 3961
                  I see what you did there. And i said brake cause he said brake lol. ;)
                  • samiam3356
                    • Jul 2009
                    • 1901
                    lol I fail evidently! love typing this shit in on my phone..:)
                    I've posted the napa part# for the correct die if someone needs it.
                    $5 shipped?
                    • StereoInstaller1
                      GAS
                      • 22679
                      Ah, replace TB hose, got it. I have only looked under 1 manifold of an OBDII motor, but I do recall that.
                      I told my bud about this, is a MUCH better way of dealing with the issue, especially on a car that is "finished". We were gonna install a tube that will allow that sensor to be installed, the $80 thingie that VAC makes...your idea is far superior.
                      Closing SOON!
                      • aaronmjr
                        • Nov 2005
                        • 82
                        So this is the rearmost sensor that you use to make your temp gauge work, correct? Sorry. I'm new to this 24V swap business. I am interested in one if so. Thanks.
                        1990 M3 / 1998 M3
                        • samiam3356
                          • Jul 2009
                          • 1901
                          X52 motors have 2 ports in the head. 1 for a 4 prong temp sensor that feeds the dme and the guage and another port for the coolant to flow to the tb. You're basically using the port for the tb coolant but the hole is smaller than a temp sensor. Solution, rethread a temp sensor to that hole. You're still going to need an obd1 temp sensor fpr the dme. 1 prong e30 sensor gets rethread. Make sense?
                          $5 shipped?
                          • StereoInstaller1
                            GAS
                            • 22679
                            Yeah, I got it now, 100% clear.
                            What is not clear to me is why the head didn't get tapped when it was off the motor before it ever went into the car! Oh well, some guys take this serious, some just don't. I wish I had been there during the build, I would have caught that...
                            Closing SOON!
                            • samiam3356
                              • Jul 2009
                              • 1901
                              Many ways to skin this cat. I believe some even wire the 4 prong temp sensor into the harness. I really didn't want to tap the head with it attached. Was worried about shavings staying in there and wreaking havoc.
                              BTW Luke my post above was for the guy above my post not you. Figured you got it.
                              $5 shipped?
