tach and fuel economy
  • luis.e30325es
    • Feb 2011
    • 128
    i tried to wire this myself, did the rest of the harness myself, this is the only part im having trouble with.
    can anyone help me?
  • EduardoGomez
    • Feb 2011
    • 48
    Last time you posted a post about your engine not starting, and it turned out you did not even have the good charged up battery!
    Will this post turnout to be something like: "ohh, I forgot this..ohh I forgot that..ohh I missed that" ?
    All the information that you need fixing those two is here:
    http://www.akgmotorsport.com/usm50swappins.php
    I know you can't get any help form AZBMW
    From Pin # For To Pin #
    '86-91 325 '92+ 325i, M3
    1 Alternator charging 25
    2 Not used
    3 Not used
    4 Coolant temperature sender 12
    5 Oil pressure 23
    6 Not used
    7 Ignition switch 21
    8 Fuel rate 24
    9 Engine Speed 20
    10 Not used
    11 Diagnostic connector 19
    12 Check engine light control 8
    13 Fuel pump relay 13
    14 Oil level fault set 14
    15 Starter motor 15
    16 Not used
    17 Not used
    18 Starter 18
    19 Oil temp X6031 pin 10
    20 Coolant temp 11
    In some 86-87 models, Speed output is
    C104 under glove box Engine speed output, BK/BU Tach 20
    • luis.e30325es
      • Feb 2011
      • 128
      2 Not used
      3 Not used
      5 Oil pressure 23
      6 Not used
      8 Fuel rate 24
      9 Engine Speed 20
      10 Not used
      15 Starter motor 15
      16 Not used
      17 Not used
      18 Starter 18
      20 Coolant temp 11
      hey man, you're really starting to piss me off..
      i wouldn't be talking shit if i were you.
      • StereoInstaller1
        GAS
        • 22679
        can anyone help me?
        Luis, what year and model is the car?
        If early, those wires don't come through C101, but you can connect the car's wires to the DME wires inside the glovebox as shown here:http://www.r3vlimited.com/board/showthread.php?t=213404
        I have not checked the color codes on your 24V harness, that is up to you.
        GL!
        Luke
        C'mon, kids, you can get along better than that. Shit talking is fine as long as it does not get nasty, both of you behave.
        Closing SOON!
        Thanks for 10 years of fun!
        • mph10909
          • 13
          Your in luck i just went through figuring out this problem
          My car was an 87
          But as Stereo Installer said it could be different between late and early models
          With mine I had to go through the wires in the glove box
          I used the connector from my old engine harness Which was a green wire that connected to a black one on the main harness
          I ran it from the glove box into the the engine harness
          Started it up and I had a perfect working tach
          Hopefully this helps I know I had a fun time figuring out what all these connectors were called
          • hoveringuy
            • Dec 2005
            • 2744
            Shameless plug:
            Don't forget that with a DOHC engine your displayed fuel economy will be massively inflated. You can correct it with one of my circuits.
            I went for a camping trip South of Mt. Rainier this weekend, pumped 10.5 gallons for 309 miles. My OBC displayed 29.5 MPG.
            I was happy about the economy on my M54 and the accuracy of the OBC!
            • glucklich21
              • 1912
              I've seen your site before^^^
              How will it know what size injectors I'm running?
              • hoveringuy
                • Dec 2005
                • 2744
                It uses Extra-Sensory Perception (ESP). It can also pick lottery numbers for you and give you an awesome fantasy team.
                (it has a trim pot that can be adjusted for your exact fuel pressure and injector combo)
