Car is an 85 325e, cammed m50b25tu, m42 rad, thermostat controlled electric pusher fan. Newer fluid, verified the fan is kicking in and working fine.
If the car idles for more then 5 minutes with temps in the 80's or more, it overheats, even with the fan running. When I start driving the temp drops right away back down to normal levels.
It never did this before in ~3 years and ~40k miles, and I haven't changed anything.
Haven't touched the coolant level in months, so it's not leaking.
I never messed with the thermostat or water pump, but I'd think those would cause major issues if they failed... not just this idle overheating issue?
