Slammed 24v e30s?
  • mo diesil
    • Jan 2011
    • 275
    Originally posted by sticksdaman
    how on earth did you break a 1/8inch thick steel plate into 3 pieces?
    did you run over a plasma cutter?
    hitting it off the ground..... ive since sold the car but ill find some pics it snapped where it mounted to the PS rack and basicly right down the middle i know im not the only person to experience this..
    around where the plate sat when it was still intact
    • mo diesil
      • Jan 2011
      • 275
      back to my question about the e30 motor werks serve duty plate ?
      • Lag
        • Jul 2008
        • 358
        http://www.r3vlimited.com/board/show...=193281&page=4 <- This is my suggestion as it raises the pan so the steering rack/sub frame are the lowest points.
        Sam
        • Tron
          • Apr 2011
          • 155
          I think you need to just be carfull my m20s oil pan is 1.25 inches off the ground and I manage just fine my exhaust is .5 inches in the lowest spot if that scrapes then I know I'm in trouble LOL. Then again the roads in AZ are actually fairly maintained at least in west Phoenix/Glendale area.
          • Tchao
            • Apr 2007
            • 223
            Maybe instead of fucking up the geometry and alignment of your drivetrain and suspension, why dont you not dump the car, and raise it a bit?
            Seems pretty retarded to shim your motor up or fuck with the subframe...dont you think?
              • 37832
              So I measured mine and the skidplate is 2.5" from the ground. I guess that's not even close compared to some of you, lol! I have big boy sized tires though.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
              • psyber_0ptix
                • 904
                yea, two birds one stone. Reduce the tendancy to roll, and bring that rollcenter back to ground level or above.
                OR.... build an extremely burly skidplate and be afraid to drive it around town.
                Iceland has pretty nice roads, or?
                Originally posted by FredK
                However, in your absence, I will likely sit in your seat buck naked while making racecar noises as if I were maxing your E30 out on the Mulsanne Straight while allowing the perforated vinyl to soak up my butt sweat (going 200 mph does that to you).
                My year in Germany
                Feedback
                • DTM190
                  • Nov 2008
                  • 1107
                  our roads are that shitty i need something like this as a skid
                  I am (cant believe i am saying this) RAISING my 24v e30 atm, it would not last a week with either skids with the pan less than 2.5" on our roads
                  Originally posted by der affe
                  first try a finger or 2, you need to have them suck on it first and get it nice and wet to help it slip in.
                  if she goes for that, astroglide up your pole, have her lay on her stomach and slip it in slowly and bury it to your balls and leave it there until she relaxes. once she is used to it slam that ass like a screen door.
                  • Dominic49
                    • Feb 2007
                    • 1373
                    Originally posted by mo diesil
                    anyone use the e30motorwerks serve duty plate? i had a raceskids one and broke it into 3 pieces
                    I use it and it takes a beating, on and off the track
                    • z31maniac
                      • 17566
                      Precisely why I like 17s on an E30.
                      You can get rid of the gap between tire/fender AND maintain a more reasonable ride height.
                      www.gutenparts.com
                      • psyber_0ptix
                        • 904
                        by off the track do you mean, about to eat a wall...or just on normal streets? j/k ;)
                        My year in Germany
                        Feedback
                        • agustingig
                          • Dec 2009
                          • 140
                          Originally posted by 327is
                          what springs are you running?
                          Running 4 inch ebay springs and billy's, Got the adjuster all the way down but i want to go lower,, Do you think i could raise the motor like 3-5cm's? And lower the car the same amount? I survived a whole summer on shitty icelandic roads with the pan at this height, But the problem is i wanna go lower next summer.. If i would raise the motor, Drop the car so the pan is at same height and get a massive skidplate, Dont you guys think id be good? :$
                          • Fusion
                            • Nov 2009
                            • 3659
                            Didn't Iceland go bankrupt?
                            • Dominic49
                              • Feb 2007
                              • 1373
                              not as bad as you guys are about to
                              • kalib0y
                                • Dec 2004
                                • 3620
                                shim it up and get an e30motorwerks plate
                                95 7.1L 16V E36 M3
                                Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                                LIKE my Facebook Page! CLICK HERE
