Trying to start up my m50, it cranks and gets spark but no fuel. We added a little starting fluid and it started for a second then shut off. I take off the fuel line from the fuel rail and its completely dry... Sounds like the fuel pump isn't getting any power, when I put the key in the on position I don't hear the pump running.
I checked over my wiring adapter and I double checked to see if the fuel rate connection (pin 8 to 24) and the fuel pump relay connection (pin 13 to 13) were connected and they were both good.
Any ideas?
Any ideas?
