99 528 swap?
  • evo30
    • Aug 2007
    • 19
    99 528 swap?
    can i use a 99 528 motor for my swap?if not what years can i use?
  • e30e
    • Dec 2004
    • 2176
    yes
    1985 BMW 325e
    1997 BMW M3/4/5
    2007 Chevy Silverado Crew Cab 5.3 v8
    • nrubenstein
      • 3148
      You can, but it will be significantly more difficult. '99 is the first year of the M52TU which has dual VANOS and for which the easy OBD1 electronics do not directly bolt on. You will want to look at hoveringuy's M54B30 swap thread to understand the difference (the M54 and the M52TU are essentially the same motors - the differences are irrelevant for swap difficulty.)
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • hoveringuy
        • Dec 2005
        • 2754
        It's mostly an OBD1 swap with a few differences and an extra circuit to control the dual VANOS.
        You can also run the stock ECU which is easier in some ways, but more difficult with EWS and such.
        • evo30
          • Aug 2007
          • 19
          ok thank you for the info guys ...
