Quick wire harness (and dme) question
  • FreedS4
    • 752
    Just bought a 92 NV 525i. It has the brown label 402 DME. I can use this DME AND it's harness for my M50 swap (into a 89 325i), correct? Thanks for your help.
    Chris
  • N2MYE30
    • Oct 2007
    • 5536
    Im pretty sure you can.
    COTM
    • FreedS4
      • 752
      That's what I was thinking, too, but I'm not positive. I've done some searching, but can't find a solid answer. Thanks for your help.
      Chris
      • FreedS4
        • 752
        So I guess the real issue may be the length of the harness, correct? The e34 harness isn't long enough to reach the glovebox, if I'm not mistaken. I could use an e36 harness with my brown label 402 DME, then, correct? Thanks for everyone's help.
        Chris
          • 34844
          yes but it has to be a '92 e36, non-vanos harness
          I used an E34 harness, what a pain in the ass. I wouldn't do it that way again..
          • FreedS4
            • 752
            Looks like I've got a lead on an e36 non-vanos harness, which will accompany my brown label 402 e34 DME quite nicely. I look forward to finally getting all the pieces together! Thanks for your help.
            Chris
            On a side note...are M50 heads prone to cracking? I had heard that rumor going around, just curious.
            • kingston
              • Jun 2010
              • 2669
              No, they are not.
              Originally posted by LJ851
              kingston is the play by play announcer for this thread.
              ‘Tis by the grace of God that my cars run!
              Originally posted by unloadedak
              #teamross
              Siobhan's Build Thread - UPDATED!
              • FreedS4
                • 752
                Originally posted by kingston
                No, they are not.
                I'm assuming your response is to this question. Thanks, I didn't think so, but wanted to see what r3v thought.
                Chris
                • MattM
                  • Apr 2009
                  • 931
                  Any DME that accompanied a NV from factory works just fine... no NV ever has EWS
                  Full Build Thread Here
                  • FreedS4
                    • 752
                    Didn't know that, but this helps! Thanks
                    Chris
