thr cab necessary?
  • Sputnik
    • Jan 2010
    • 808
    thr cab necessary?
    I know that those treehouse racing cab's give you more clearence for m/s50 swaps, but are they necessary or just a luxury?
  • xwill112x
    • Jan 2009
    • 4236
    yes its necessary
    • e30rapidic
      • 2167
      no they aren't. I am not running them in my S50 cabrio......
      FWIW, I am running Raceland headers
      '87 325ic, powered by S50.
      • Sputnik
        • Jan 2010
        • 808
        Are you running these http://cgi.ebay.com/ebaymotors/Exhau...Q5fAccessories
        Did they pop right in without any bending or modification?
          • 37828
          Definitely NOT necessary. Out of the 10 or so swap cars I have personally been involved with not one has had them and I believe all of them have run the eBay long tube headers that most people here use.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
          • e30s50dan
            • Nov 2008
            • 2076
            ss headers ebay...no treehouse here.offset powerflex bushings
            NASA
            BMWCCA member
            PCA member 25yrs
            1991 318IS slick top
            1997 M3 sedan
            2001 325CI DD
            “whoever turns the wheel the least, wins"
            • DTFE30
              • Feb 2011
              • 471
              My car had treehouse CABs on it installed by the PO. It does provide plenty of clearance but is not needed. The ebay SS headers worked great.
                • 34834
                Originally posted by xwill112x
                yes its necessary
                facepalm..
                • Sputnik
                  • Jan 2010
                  • 808
                  Thanks for all the responses guys, I just wanted to get the facts straight and not have to spend another $200
                  :D
                  • Wishno87
                    • 6025
                    It depends on the headers you get.
                    • z31maniac
                      • 17566
                      Not necessary.
                      yes its necessary
                      OP, basically ignore any piece of technical advice given by this member and you will be light-years ahead of the game.
                      www.gutenparts.com
                      • ACHTUNG
                        • May 2005
                        • 2397
                        yes its necessary
                        You are incorrect.
                        1989 US E30 Cammed S52
                        Under Construction: 1983 Euro E28 Cammed LQ9/LS3 Heads/Jakeb E28 LSx Kit
                        • 328ijunkie
                          • May 2007
                          • 3961
                          Fail
                          Check Us out on Facebook
                          Full Product Line Tuning
