m50b20 help
  • zewolfen
    • Aug 2011
    • 21
    m50b20 help
    heey all
    I am new here to this form.. and i have a question please bare with me.. i am also kind of new to the bmw swaps .... i have e30 1989 it was stock 318 and i swapped to the m42 from an E36 1995 and after 6 months i had some problems with the m42 so i swapped to M50B20 but with the m42 Gearbox getrag 240.. and with differential non lock 3.64.... the problem is i cant go over 200 km/h , 122 mph ..... also the 5th gear almost useless.......
    Can any one help me please..... Thnx :)
  • zewolfen
    • Aug 2011
    • 21
    is there is any one going to help me ? ?
    • Wh33lhop
      • 11705
      200kmh is 126mph which sounds about right for a 2 liter.
      What does "useless" mean? Your 5th gear is about the same as a stock 325i's 5th.
      paint sucks
      • Gruelius
        • Oct 2009
        • 298
        sell the car buy a e46 m3
        RIP 84 323i coupe 5spd w/ 14psi
        89' 318i
        • jrdeamicis
          • Nov 2008
          • 956
          Get a different diff. Done. 3.25 or 2.93. Voila
          Past Car : E30 S50 6 Speed 5 Lug 3.73
          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
          ___________________________________________
          BNB Designs
          Engine Swaps, Fabrication, Innovation, General Repair
          Richmond CA
          Julian 848-248-8029
            • 34844
            i don't get how a stock M42 with a 4.10 and G240 can do ~130mph but an M50B20 with a 3.64 can't do over 122?
            • trackjunkie21
              • Jan 2010
              • 3962
              obviously something is wrong with the m50.
              Originally posted by Wh33lhop
              VANOS: sometimes you just need to go full retard.
              • zewolfen
                • Aug 2011
                • 21
                okay i will tell you why its useless ... for example when i am on 180kmh with the 5th the car sticks to 180kmh and it doesn't have the power to go over that ... but when i switch to the 4th gear i reach 200kmh fast...thats why i feel the 5th gear is useless...... and i cant go more than 200kmh .. some one told me thats because i have 17 inches rims
                do you have any idea about that ? ?
                and what if i switched to G250 ?
                • zewolfen
                  • Aug 2011
                  • 21
                  and something else i wanna tell .. i have free flow 2.5 inches exhaust ... does it sound good for M50B20 ? ? ?
                  • Mr.SWISS
                    • Nov 2005
                    • 1251
                    Dude that motor sucks, I couldn't justify a swap for a 10hp bump over what you had.
                    Originally posted by 325Projectz
                    don't listen to the diagram... listen to mr. swiss.
                    :nice:
                      • 34844
                      yeah, I'm thinking the M50B20 is just weak. Perhaps the gearing is even too tall.
                      • zewolfen
                        • Aug 2011
                        • 21
                        its weaker than the m50b25 but that doesn't make it stay on 200 kmh i dont know where is the problem.... is it the differential too short ? but i dont think so its 3.64.... maybe the exhaust but its 2.5 inches but all i know its so fast it goes to 200 very fast
                        • MattM
                          • Apr 2009
                          • 931
                          lowering the ratio will just make the rpm lower that its doing at 200, and will take you longer to reach those speeds. IF they engine doesn't have the power then it doesn't have the power. I am not really surprised that a stock M50b20 can only hit 200.
                          You can try to boost the power with chips and bigger injectors and stuff, or put a bigger engine in. No replacement for displacement
                          Full Build Thread Here
                          • zewolfen
                            • Aug 2011
                            • 21
                            do you know any recommended chips for that engine ? ? ?
                            • The Humjet
                              • Jun 2010
                              • 528
                              Maybe you can put shorter a 3.91 or 4.10 diff in it so the the b20 can have enough power to push it beyond 200km/h. My SLOW m40 with only 80whp can make make it to 190km/h with a 4.10 diff and that was in 5th gear running out of revs to allow it to go faster.
                              Also may I ask your not running a big F1 wing on the back are you?
