OBDI wiring harness diagram
  • BADCLOWN
    • 399
    yes, i looked on here and i searched around on google and found little bits but, im looking for a very comprehensive and descriptive wiring diagram for OBDI wiring harnesses.
    if anyone has a detailed wiring harness for and m52 OBDI swap please help a brother out.
    FOR SALE: diamantschwarz metallic 1991 m52 e30
    silbergrau metallic 2004 330i ZHP
  • AndrewK
    • 37
    Bodykit courtesy of BMW M GmbH.
    • N2MYE30
      • Oct 2007
      • 5536
      Im sure there may be diagram that will be perfect but I found that if you want to perfectly sure of the wiring, have both ETMs out and do it yourself. I tripled checked one that I found on the interwebz and I had to modify it to work on my specific wires.
      COTM
      • e30shmobberr
        • 1934
        since they dont have a 1995 m3 specific one, would the m50 one be the same?
        Patrick - IG:niicknac
        RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, bagged
        • scottinAZ
          • Dec 2009
          • 1312
          from what I saw when I did my wiring search, the M50 is the basic wiring, and the addidtions/changes/subtractions are noted in the diagrams for the various other configurations. Best "listing" I found was this one
          http://www.rmeuropean.com/bmw-e30-m50-swap.aspx
          but I would HIGHLY suggest that you check the wires with the ETM yourself to avoid issues.
          I saved 15% on my Bimmer parts by switching to ...
          • 328ijunkie
            • May 2007
            • 3961
            That RM european one has some issues.
            Check Us out on Facebook
            Full Product Line Tuning
            • scottinAZ
              • Dec 2009
              • 1312
              The colors and positions matched up with mine, 1987 car to 1994 engine. As I stated before, YMMV depending upon the swap donor used.
              If there are any major oversights on my part, please feel free to elaborate past "some issues"
              • jrdeamicis
                • Nov 2008
                • 956
                If you pull up the m50 95 one, they have M3.1.1 also which is an S50 engine management.
                His OBD1 side is pretty correct
                Past Car : E30 S50 6 Speed 5 Lug 3.73
                Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                ___________________________________________
                BNB Designs
                Engine Swaps, Fabrication, Innovation, General Repair
                Richmond CA
                Julian 848-248-8029
                  • 34844
                  even if it matches up most charts I've seen, including that one, don't bother to do things like power up the diagnostics port or ABS on later cars. they also don't include M3 or ix specific pinouts.
                  • Jean
                    • 18228
                    Originally posted by AndrewK
                    • scottinAZ
                      • Dec 2009
                      • 1312
                      Fair enough. The ABS isnt an issue on my early model, and powering the diagnostic connector was handled through another chart. as long as those are the main issues, Im OK then :D
                      • kingston
                        • Jun 2010
                        • 2669
                        OK, I'm clearly doing something wrong, or not understanding something. I'm trying to help a friend do a pinout chart for a `91 318is using the Wedophones site, and I flat out cannot find a few connectors listed. I've been unable to find #s 8, 9, 11 & 12.
                        What am I doing wrong? Am I really just missing these over and over in the ETM, or are they listed somewhere else?
                        Thanks guys!
                        Originally posted by LJ851
                        kingston is the play by play announcer for this thread.
                        ‘Tis by the grace of God that my cars run!
                        Originally posted by unloadedak
                        #teamross
                        Siobhan's Build Thread - UPDATED!
                        • DaveSmed
                          • Apr 2007
                          • 1407
                          Thanks guys!
                          You'll find those in the instrument cluster section, not the injection electronics section.
                          -Dave
                          2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
                          Need some help figuring out the ETM?
                          • 328ijunkie
                            • May 2007
                            • 3961
                            ^That. Also look at the AC section, and check control section for more connections ;)
