Im stuck right now for the most part buying new tubes is the biggest problem. My welder is great and isnt expensive but the supply of used tubes just isnt there.
Any Interest in New OBD2 24v swap Dipsticks (working CCV)?
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno Thread -
‘Tis by the grace of God that my cars run!Originally posted by LJ851kingston is the play by play announcer for this thread.
Siobhan's Build Thread - UPDATED!Originally posted by unloadedak#teamross
Thats cool. Great find.i went the e39 m5 separator route. just installed on sunday so too early to tell how much it has helped, if it has at all.
Host your images online with an easy to use image uploader, albums, photo hosting, sharing, dynamic image resizing on web and mobile.
some more info on it if anyone is interested in it:
http://en.wikipedia.org/wiki/Cyclonic_separation
But what is the advantage to this one over the stock OBD2 separator?
I'm guessing that it's just better designed (looks more simple) and more durable with less things fail. I know the OBD2 e36 one has to be replaced often because something in it goes bad.
I'm thinking about going with this one instead of the stock OBD2 one.
It's only $33 too! That's way way cheaper than the e36 OBD2 one.
Zinno '89 <24v swap in progress>
Custom is about your only option...
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
