IMO no; its too short for anything under 8,000 rpm redline
single throttle 24v engines are too weak on top end power to utilize such a short final, you will be stuck in no hp no torque land (past the peak power zone per dyno chart)
my own 24v swap was paired with 8,388 rpm redline and OEM 24v 5 speed transmission+3.38; it was actually pretty damm good.
4.10 would have irritated me and caused a reduction in speed of car from too many shifts, with the increased HP and Torque of my swap I actually wanted to drop the final drive down from 3.38 to a 3.15.
24v car would be faster with longer gearing for less shift since it has a decent horsepower/torque advantage over the 12v lump. Popular ratios for 24v swap's with proper matching transmissions are around 2.93-3.23.
Out of all the Diffs I have configured for 24v swap weapons not a single one was a 4.10...........
I ran a 4.10 on my e36 m3 Automatic transmission car; it was actually long legged enough (5th super overdrive) to utilize it.
If one does a S52+5EAT ZF HP518 swap, then 4.10 is the killer item.
4.10 + any proper 24v 5mt transmission (all are non-overdrive 5th)= no first gear start in 2nd - effectively a 4 speed.
If you put in a Getrag 6 speed + 24v swap and add a 4.10 final drive you are basically throwing away the 6th gear.
