worth while M50 NV mods
  • mo diesil
    • Jan 2011
    • 275
    ok i know you can hot cam it, and short of a turbo what else? anyone experiment with different injectors or any thing?
  • 328ijunkie
    • May 2007
    • 3961
    Better engine haha.
    Check Us out on Facebook
    Full Product Line Tuning
    • mo diesil
      • Jan 2011
      • 275
      Originally posted by 328ijunkie
      Better engine haha.
      i dont see why... its a very capable power plant
      • e30polak
        • 6136
        Turbo, that's it.
        INSTAGRAM: @UNDR8D_EMPIRE
        • lolcantturn
          • 4588
          Turbo. nothing else..
          Originally posted by TSI
          OEM+
          • 328ijunkie
            • May 2007
            • 3961
            Throw a few grand at it NA, let me know your results and if you still think its capable then.
            • Wanganstyle
              • 2828
              seriously, the only NA modding you can really do with a M50 nonvanos is:
              stroke and bore to 3200cc or more (ala s52)
              Add s52 cams to it and vanos.
              so basically you will have a S52 at the end with double valvesprings but thicker and heavier (and tiny little bit less flowing) valves.
              • 328ijunkie
                • May 2007
                • 3961
                ^That.
                The M50NV is a technologically advanced M20. And not much advanced at that.
                • mo diesil
                  • Jan 2011
                  • 275
                  i think you guys got the wrong idea, i was more wondering if any had experimented with other mods..
                  turbo is what i plan for the car but was simply wondering what people have done,
                  • devon.818
                    • Feb 2011
                    • 2937
                    Haven't done these but read about them as options.
                    Underdrive pulleys
                    Big bore throttlebody
                    Cam
                    Chip
                    Change your gearing
                      • 34835
                      none of those things are going to make any real difference other than a cam, chip, and perhaps gearing.
                      • ecc3189
                        • Oct 2009
                        • 33
                        I have read that the m52 tubular exhaust offers more torque. Bigger TB, Injectors, chip, and underdrive pulleys are the only bolt on mods I can think of right now. A lightened flywheel will help throttle response and if you want to start getting into machining you can always do a valve grind/porting.
                        I'm going with a m50NV for the electrical simplicity and to make it easier to turbo down the road. I'm not too worried about being happy with it since I already love the torque in my eta engine and the nv should feel about the same with another 60 hp to play with...
                        For Sale thread: e30 and e36 Parts
                        • 328ijunkie
                          • May 2007
                          • 3961
                          M50NV wont really benefit from a valve grind/porting. esp with the stock cams.
                          Chip and OBD2 manifolds are about the only things that really do anything for that motor.
                          • N2MYE30
                            • Oct 2007
                            • 5536
                            I knew going into mine that NV mods were limited to just about a chip. Im having a great time with mine stock and once I get my chip, Im sure ill be more than happy. Sure, and S5x and forced induction would be nice (near dangerous in my hands) but Im content with my setup.
                            COTM
                            • mr2peak
                              • 2388
                              Get a 4.10lsd if you don't already have one, best mod i you are staying N/A
                              Drive it hard. Maintain it well.
                              A Topless Memorandum
