M60b40 VS s50b30 E30 Swap
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image. -
I really want to see someone with scales measure all motors under the same conditions (fluids, dry, accessories, or none) because there always seems to be a shitload of different measurements.
If I pick up the M62 I saw today, I'll be able to set it side by side an Ls1 this winter, though!Comment
You need both ends, the front being the more important because of the large flex disc flange to mate up with the B30 5 speed. The E36 328i DS will also work, as well as the E30 M3. Biggest reason to get the whole DS is so you don't have to have it re-balanced...
Garey
Depends on what vehicle they're out of. ONLY E39 540, late E38 or X5 manifolds will work. The drivers side needs to be the 4 into 1 design to clear the steering column and the passenger side is tight enough, even without the column, so the 4 into 2 into 1 makes it a little simpler to route the exhaust down without major firewall shenanigans...
Here are some pics of my modified manifolds next to a pair of late E38 manifolds. Notice the differences. These are the style you need for this swap...
Modified in the middle...
Drivers side, modified on the bottom...
Passenger side, again, modified on the bottom...
GareyLast edited by bmwmech1; 09-21-2011, 05:52 AM.
perfect, thanks again-
I appologize for all the "clarity questions" but it's nice to know someone is doing this aswell....it's easier than the costly "trial and error" route I was travelling down.Originally posted by flyboyxi have watched my dog lick himself off a few timesComment
I've got a m62 fs for 550 with under 100k on it. pm me if you wanna check it out.My Multi car part out. Need a part? Pm me...
http://www.r3vlimited.com/board/showthread.php?t=193051
Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
http://www.r3vlimited.com/board/showthread.php?t=215044
Have you done business with me? If so leave me feedback here...
http://www.r3vlimited.com/board/showthread.php?t=188307
Source for this info?
Photographic examples of LS1/E30 engine placement?
The LS1/Miata has a similar problem in that the bellhousing is just a little too wide for the transmission tunnel. With fairly minimal modification to the trans tunnel--which, AIUI, does not affect fitment of any interior components--the engine can be situated properly in the compartment. Maybe the E30 is similar?
Regardless, the S5D-310Z bellhousing for the M60 fits, as does the rest of the transmission with essentially no modifications.Comment
Main difference between the Miata and an e30 is you're gay in the Miata, in the e30...it's debatable.
I have friends who auto-x Miatas, so don't tell me about how well they do, I still make fun of them.1974.5 Jensen Healey : 2003 330i/5Comment
Its only debatable when you cover the thing in argyle.
Also E30>E28.1986 Plymouth Horizon. Base.Comment
I weighted my m10 and m30, will do the same with m60 :)
scroll up, was posted here.Source for this info?
Regardless, the S5D-310Z bellhousing for the M60 fits, as does the rest of the transmission with essentially no modifications.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Oh yeah... I knew it had been mentioned in this thread; just forgot it was a shop actually doing it.
I *DO* have questions about an engine sitting too far forward because of the transmission when it's *ALSO* sitting too high...
I haven't read Garret's entire thread ( http://forums.bimmerforums.com/forum...d.php?t=699289 ), but I did find a picture of the engine looking a bit further forward than it should ( http://forums.bimmerforums.com/forum...3&postcount=93 )
I *Quickly* glanced through the Vorschlag build thread ( http://www.corner-carvers.com/forums...ad.php?t=42099 ) but couldn't find a comparable shot of their car. They didn't use a T56 anyway.
Anyway, it looks like the modified GTO pan is what's keeping the engine up, and what's keeping it up is what's keeping it forward.
I have a hard time believing that with the multitude of products like this on the market: http://www.summitracing.com/parts/MOR-20140/?rtype=10 that the modified GTO pan is the *ONLY* way to make that engine fit. Not buying it. Vorschlag built theirs the way they did because they were building it *DIRT* cheap. Everyone else who's built there's the same way since then is copy-catting.
Spending a couple hundred on a drop-in pan seems like a no-brainer to me...Last edited by The Dark Side of Will; 09-23-2011, 09:25 AM.Comment
