Whats it worth?
  • mbonanni
    • Sep 2011
    • 6236
    Whats it worth?
    1986 bmw 325es with 24v swap.
    1998 m52 engine with 130k on engine converted to OBD1
    5 speed ZF320 tranny
    3.25LSD
    328i 5 speed driveshaft with new clutch
    engine has every single gasket changed car has no leaks at al
    e36 black interior
    There is more, here are some pics also
    Thanks
  • MaxBell
    • 1391
    Pretty!! Anywhere from $2800 to $3500 depending on the rest of the car from the engine.
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
    • mbonanni
      • Sep 2011
      • 6236
      What other thing are you talking about?
      Thanks
      • mbonanni
        • Sep 2011
        • 6236
        here is also more details
        196k on chassis.
        Lowered on H&B springs with Billy HD shocks
        01 BMW M coupe shifter
        I am looking to buy this car. I am skeptical on how much to offer.
        Also is this car completely CA legal?
        OBD2 motor converted to OBD1?
        • MaxBell
          • 1391
          Well, in Canada the question is rust. If there is ANY on the chassis, then it's suddenly worth about $500-$1000.
          If the car is rust free and stock, maybe around $2500.
          As you go up in value, you're going to be hitting engine swapped cars at around $3000.
          I find turbo cars are around the $4000 range, those vary depending on the components and quality of the job.
          The $6000+ cars are usually cars that have serious engine swaps or mods, or strange body mods, such as M3 convertibles and the like. The sky is the limit with these things.
          • mbonanni
            • Sep 2011
            • 6236
            No rust, has the specs I listed.
            Does anyone know anything about cars being bar'd?
            My budd has an s5(?) swapped e30 and said I should not get this car because it is not barr'd.
            He said cars must pass the bar to be legal.
            Any help is highly appreciated
            • reelizmpro
              • 9543
              Just have to make sure it's a clean swap with all of the emissions related parts from the donor car. The less 1/2 assed or customized stuff the better.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • mbonanni
                • Sep 2011
                • 6236
                The guy said he has a full custom exhaust but he has the cat that he can swap out to make it pass smog.
                I am worried about buying the car without a bar sticker. Can I get in trouble if I do not have this?
                I read it is required for any motor swap, stock or non stock.
                Also I read that you cannot get a bar sticker if you convert form obd2 to obd1? is this correct.
                Thanks guys.
                • jrdeamicis
                  • Nov 2008
                  • 956
                  Hi!
                  If the car is local to the bay you can bring it down to our shop and we can check it out for you. I can also let you know if it was done half assed or if it would not pass smog / CARB. We can also help you get it through the process.
                  Feel free to contact me with any questions.
                  There is a lot of details that set the value of that car. I really check for the little things like small covers, fender liners, proper mounting, emissions, functionality.
                  Past Car : E30 S50 6 Speed 5 Lug 3.73
                  Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                  ___________________________________________
                  BNB Designs
                  Engine Swaps, Fabrication, Innovation, General Repair
                  Richmond CA
                  Julian 848-248-8029
                  • mbonanni
                    • Sep 2011
                    • 6236
                    thanks guys.
                    I pm'd you jrdeamicis
                    • MaxBell
                      • 1391
                      Nice shameless plug there. Good idea to get it checked out by a professional either way.
                      (unless you are a semi-profressional, then get an idiot to check it out, so they can tell you whether you should buy it or not based on looks alone)
                        • 37832
                        Judging by that terrible engine bay picture the swap looks very messy.
                        Not everyone with a swap in CA has had their car BAR'd. Mine isn't and I've been running the swap for almost 4 years.
                        Classic BMW Specialists
                        Grover Beach, CA
                        www.BimmerHeads.com
