I cannot seem to find any info on how to use the e34 motor harness for my m50tu swap. Harness came out of a 94 525i auto (engine and trans harness were seperate one those) What do I need to do for my car side plug? Any info would be perfect, especially a pinout. Thanks!
E34 Motor Harness Question
Tags: None
you need to do the same thing as you would to any harness - convert the pinout from X20 to C101. For the most part the E34 harness is the same except it has the oil level sensor wiring built in (pins 2 and 10). -
Finally got around to working on this, so are you saying most of the wire color combo's are the same? Any advice as to what page on the manual to use? Cant find just a pinout anywhere. http://www.wedophones.com/Manuals/BM...g%20Manual.pdfComment
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
there is no pinout. you have to look for the pins labeled C101 on the E30 harness diagrams and X20 on the E36/E34, write them down and then match them together by function (most of the time the wire colors match too).Finally got around to working on this, so are you saying most of the wire color combo's are the same? Any advice as to what page on the manual to use? Cant find just a pinout anywhere. http://www.wedophones.com/Manuals/BM...g%20Manual.pdfComment
At the very top of this sub-forum, there is a sticky thread titled "Are you interested in doing a 24v swap? Read this!". In the very first post of that thread, I describe how to do the wiring for any BMW engine swap.Last edited by JGood; 11-08-2011, 06:38 AM.Comment
