Feel free to give me a shout ;) I can help you out with the Cyl head and stuff!
need help, knocking noise
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno Thread -
overrev, stuck lifter, etc
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
[quote=Rugbyfan;2826353]Update 10/31/11
My thoughts: what could’ve caused this when the motor hasn’t gone over 4k rpm’s in the last 2k miles? Why now?
Rugby: Bear with me because I'm the novice of things automotive but the valve problem occurred after the fuel pump swapped, yes? Could a valve become bent from running the engine dry trying to restart? Or from spraying in an excess of starter fluid during that restart?1991 325iXComment
