might have a lead on an m54b30 swap.
  • Pantless Spency
    It's McRib time!!!
    • Feb 2011
    • 7283
    so i might do work for some place, and in return get an m54b30 for a swap, what would all need modifying for the swap? obviously ECU, harness, brake booster etc.
    but what about engine mounts, what about a tranny? not so sure if i want to do this or not.
  • 328ijunkie
    • May 2007
    • 3961
    Who is gonna do the swap? If theyve never done one before walk away.
    Check Us out on Facebook
    Full Product Line Tuning
    • nrubenstein
      • 3148
      Everything but the electronics will be exactly the same as any other swap. Hoveringuy has worked those out, so you can buy his circuits.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
      • 328ijunkie
        • May 2007
        • 3961
        an M54 shouldnt be running OBD1 IMO.
        • nrubenstein
          • 3148
          Why? It seems to work. Solving the EWS issues with an E46 OBD2 swap would be expensive.
          • lolcantturn
            • 4588
            you are going to be for one hell of an adventure if you've never done this before.
            Originally posted by TSI
            OEM+
            • hoveringuy
              • Dec 2005
              • 2743
              Wow, M54's are starting to fall from the sky!
              • lolcantturn
                • 4588
                at least they're becoming trendier and trendier :)
                OEM+
                • TimKninja
                  • 2131
                  Stick with the m20 for now. Mister 2300 posts and still hasnt fixed his headgasket.
                  1985 325e M50TU(Sold)
                  1991 318is Slicktop (Sold)
                  1990 325is Brilliantrot S50/5 Lug Swapped.
                  1992 525i Manual shitbox Winter Beater
                  • Pantless Spency
                    It's McRib time!!!
                    • Feb 2011
                    • 7283
                    well i just had it sorta offered, pretty sure the guys have never done one. i talked with some other people and i hear it's just quite a bitch, and they are more delicate than an m20, and tim,as i found out yesterday it has a snapped head bolt :/ so now i'm trying to open up my options, don't wanna dump hella time effort and money into an eta..... i'm on the market for an m20b25.
                    • MattM
                      • Apr 2009
                      • 931
                      you cannot easily convert an M54 to obd1 because it is dual vanos.... there is no dual vanos obd1 engine in existence. Your going to have to either add all the ews and other components to complete obd2, or run a standalone system($$$$$)
                      Full Build Thread Here
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        ^ Sadly that is right and wrong.
                        Hoveringuy has a Dual vanos circuit which seems to work great!
                        I think OBD1 M54B30 is great. OBD1 is a great engine management. OBD2 has its ups and its down. They are just different. But for an E30 OBD1 is great.
                        Past Car : E30 S50 6 Speed 5 Lug 3.73
                        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                        ___________________________________________
                        BNB Designs
                        Engine Swaps, Fabrication, Innovation, General Repair
                        Richmond CA
                        Julian 848-248-8029
                        • hoveringuy
                          • Dec 2005
                          • 2743
                          You used to not easily be able convert an M54 to OBD1. I've shown that it can be done and that the motor is reliable and makes good power. It's only slghtly more difficult than any other OBD1 conversion. The VANOS control circuit takes care of all the nasty dual-VANOS and DISA stuff for you.
                          I've actually had mine on Megaquirt3 for the last two weeks now and it's running as well, or better, than before so that's another option.
                          • TimKninja
                            • 2131
                            Good, DONT waste time on the B27! TRUST ME. I rebuilt mine and three or four months later got sick of how slow it was and ripped it back out for a 24V Swap. It was such a waste of money.
                            Tho I imagine anything is faster then that W123 ;)
                            • 328ijunkie
                              • May 2007
                              • 3961
                              Run an M54 on stock ECU and run it on OBD1 with whatever additions you want and see if they make equal power.
