overheating...
  • trackjunkie21
    • Jan 2010
    • 3962
    #31
    Originally posted by isra
    Fuck! I dont want to change the headgasket lol... But i hate seeing my car in thr driveway full of dust!
    IF YOUR HEAD IS CRACKED A GASKET WON'T HELP. Please read....
    Originally posted by Wh33lhop
    VANOS: sometimes you just need to go full retard.
    • isra
      • 177
      #32
      Lol.. I Will remove head an get it checked. If is a small crack can it be fix?
      • Jszy25
        • 352
        #33
        Seems to me like your heater hose let go, causing you to lose coolant when pressurized, causing an overheating issue, causing a compromised head gasket and possibly worse.
        I wouldn't say the head is cracked with 100% certainty. It's probably warped though
        Have you drained the oil? What does it look like? Have you done a compression test? If so, what are the numbers?
        91' 318is - OBDI M52/ZF swap w/ S50 cams
        • Wanganstyle
          • 2828
          #34
          no. if there is a crack or warpage, TOSS THE HEAD. Trash.
