overheating...
  • phreshkid
    • 4655
    Originally posted by isra
    Thanks for the help guys... Well i worked on my car today an after taking thermostat out an driving it car still overheated so im thinking that maybe is te water Pump what do you guys think? Also today i removed the Valve cover an notice that the inside of the Valve cover an the oil CAP have some kind of water an oil mixture it looks yellowish. But my oil looks clean also head looks pretty good... Ideas..?
    This is bad.
    • rlddlr53
      • Oct 2009
      • 1450
      Take some pictures and post them of the oil. Hopefully you do not have a head gasket problem... but the yellowish mixture is not a good sign
      Make sure you bled you system properly. e36 radiator with attached bottle?
      • trackjunkie21
        • Jan 2010
        • 3962
        You need a headgasket my friend, "yellow" oil is a huge no no.
        Originally posted by Wh33lhop
        VANOS: sometimes you just need to go full retard.
        • isra
          • 177
          my oil is not yellow, it just has that mixture in the cap an the inside of the valvecover around the oil cap. im using a e30 late model rad, i hope is not the headgasket i dont feel like doing it lol... but then again i can upgrade to s52 :D
          • Philo
            Ich esse kleine Kinder
            • 3334
            Sometimes condensation on the inside of the valve cover will cause a yellowish film on the oil cap. As long as it is minimal, and the cam tray and dipstick isn't showing any signs of mixed fluid, I wouldn't worry about it.
            But then again, you are having an overheating problem.
            -tim
            Originally posted by Jordan
            I like the stance
            • isra
              • 177
              Well i Will change all my cooling system before i change the headgasket,its alot of work lol... My car runs fine idles 700-800 it just overheats.
              • Philo
                • 3334
                I also recommend checking the temp with a thermal gun. My temp gauge reads red hot, but the engine is cool as can be.
                -tim
                I like the stance
                • DesertBMW
                  • Aug 2011
                  • 1040
                  I can tell you for sure that you got cracked cylinder head. Engine is consuming coolant. This is common problem and weak spot for M5x series engines.
                  • isra
                    • 177
                    Will a crack head make the car overheat? Does it matter that my oil looks good?
                    • DesertBMW
                      • Aug 2011
                      • 1040
                      Yes. Crack will be from one of the water passages to the intake valve seat, very hard to spot. Oil won't get contaminated.
                      Example here:
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        I have a few spare heads at the shop if you need one.
                        Past Car : E30 S50 6 Speed 5 Lug 3.73
                        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                        ___________________________________________
                        BNB Designs
                        Engine Swaps, Fabrication, Innovation, General Repair
                        Richmond CA
                        Julian 848-248-8029
                        • isra
                          • 177
                          okay guys so my car is still overheating i change the waterpump,rad,thermostat,rad cap,hoses, an car still overheats..! i drove car with an without thermnostat, no difference car overheats in 5-10 min..
                          what i did notice is that the bottom heater hose on the firewall has a leak an i can see steam coming out of it plus the antifreeze in the ground. you guys think that can be my problem...? or should i start buying the headgasket..? lol PLEASEEEEE HEEELP!
                          • mr.vang
                            • 4371
                            pull out your oil dip and drip some oil on the hot exhaust manifold, if is sizzle then your oil is mix with water, if it smoke then its just oil.
                            • DesertBMW
                              • Aug 2011
                              • 1040
                              PLEASEEEEE HEEELP!
                              So I told you head is cracked and you still keep spending money on parts and engine still overheats
                              • isra
                                • 177
                                Fuck! I dont want to change the headgasket lol... But i hate seeing my car in thr driveway full of dust!
