i was driving home on tuesday after work an my car started to overheat. i got home an check coolant an there was no coolant i check for a leak an there was no leak. then i pulled my valvecover checked oil an oil level was perfect also oil was clean where did my coolant go...?
since tuesday my car is sitting in my driveway , i worked on it today, i flush the rad , i put fresh coolant i replace the rad cap with a new one. i check oil for the second time everything looks good, i then turn car on it turns one no problem..! i let it idle for 10 min then take it out for a drive on the freeway an after 5-10 min car hits the red mark , i get home let it cool for an 1 hour check coolant an half of it i gone...! WTF where is it gooing.?
what do i check next , my thermostat is new i replace it when i did the swap, my engine is m52 obd1 any ideas???
