Torque setting for the intake mani?
  • N2MYE30
    • Oct 2007
    • 5536
    I couldnt find in r3v but google search reads it as 20Nm. Correct?
    Also, is there a tightening sequence?
    Cheers!
    COTM
  • mattdk318i
    • Jun 2006
    • 3953
    umm, tight bolt never came loose....lol
    • Jafxod
      • May 2011
      • 1301
      tight enough to hold it down, loose enough to not crack the plastic
      • AnimalE30
        • Aug 2009
        • 266
        Does anyone else have a tough time installing the nut next to the fire wall? Gets me every god damn time.
        • N2MYE30
          • Oct 2007
          • 5536
          Im looking for the exact spec...a number if you please.
          Yes, that last nut is a pita. I grease up the nut and put it in the socket and aim away (man that sounds dirty) lol
          COTM
          • MaxBell
            • 1391
            For an M50, I looked up and found 3 torque specs.
            M8 = 22 nM
            M7 = 15 nM
            M6 = 10 nM
            Here's the full spec list.
            http://www.bmw-m.net/TechData/torq/bmw_torq.pdf
            REMEMBER: Be safe and have fun is Rule Number 1.
            The Epic Unbuild of Clint Eastwood
            • gobuffs
              • Dec 2004
              • 513
              20 sounds about right. It isn't much.
              • trackjunkie21
                • Jan 2010
                • 3962
                r3v and their jokes. I don't know about you guys, but I prefer a legitimate Torque rating then just as tight as you can. Tighter doesn't always mean better.
                Originally posted by Wh33lhop
                VANOS: sometimes you just need to go full retard.
                • JeremyE30autox
                  • Dec 2010
                  • 404
                  Oh the places you can go with that quote.
                  On the other hand. To the OP, it is 20
                  Dare 2 Dream Motorsports
                  • N2MYE30
                    • Oct 2007
                    • 5536
                    Thanks for the facts guys. :up:
                    COTM
                      • 37832
                      You guys fucking crack me up with your torque specs.
                      Let me tell you where torque specs are important... Head bolts, main bolts, rod bolts.
                      No, I'm not an ignorant redneck.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • e30rapidic
                        • 2167
                        ya think? Hopefully I'll never have the displeasure of riding in a car you've worked on then. Suspension doesn't matter?? How about lug nuts??? Gotta love warped rotors!! hmm. Flywheel? Pressure plate?? What about anytime you are running a bolt through aluminum? ie exhaust manifold bolts? and no worries about stripping out those oil pan drain plug threads right?
                        "they ain't loose or snapped so they gotta be a'ight"
                        '87 325ic, powered by S50.
                          • 37832
                          It's called knowing what the fuck you're doing.
                          I'm not joking, your reply had me laughing out loud here at work. I can promise you I've layed hands on more E30's than you can dream of with no ill results. Believe in your exhaust manifold torque specs and leave the real work to the big boys.
                          Grover Beach, CA
                          www.BimmerHeads.com
                          • mattdk318i
                            • Jun 2006
                            • 3953
                            thanks matt, i knew i liked you. No homo
                              • 37832
                              :giggle:
                              Grover Beach, CA
                              www.BimmerHeads.com
