M42 rad + M50 overheating woes.
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
Got it. took a couple of tries but it worked. Kind of had me worried. Sketchily bought M50 + I let it overheat to the red = me fearing for the worst, but I revved it to like 5000RPM for 10seconds, opened the bleed screw and let the air bubble out, fill up again, close everything, and repeat that process for about 5 times. drove it around, temp gauge was still climbing but it finally hiccuped and it was fine. pulled over, bled it twice again, and it's been great. Best test was as soon as I bled it I had to drive it to my friends house which meant escaping Philadelphia at rush hour, litterally standstill traffic for like 8 minute intervals- not a single problem.
This is with a 14" Ireland Engineering fan. you guys just need to bled your system correctly.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
Let me say it is a motherfucking bitch to bleed this rad but it's worth it.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
My e30 thread...http://www.r3vlimited.com/board/showthread.php?t=120348Comment
oh, thanks, ill remember that. :)you guys just need to bled your system correctly.-Jay
2014 NASA FL se30 champ #81
2001 se46 3 year plan in progress
Swing wild, brake later, don't apologize.
'89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.FYYFFComment
You should post a video and make it a sticky.
Ramps? There is no way in hell my front end would ever clear one of those.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
Not sure if it works in this case but I heard a lil trick from
My automotive professor. He use to put a baby aspirin behind the edge of the thermostat to allow the coolant to circulate immediately then when it's up to temp the aspirin disolvesDave @ Bimmerbuddies
Contact Bimmerbuddies for all your Parts and service needs
M20,24V,5spdSwap,Weld,Fab,Tow,Buy/Sell/Trade
Bimmerbuddies LLC
717-388-1256
2971a Roundtop Rd, Middletown PA 17057
*Ask about discounts for R3V members*Comment
