Got an M42 rad. Got an 80*C t-stat. Got a 14" IE Fan wired in properly. Brand new coolant temp sender (to the gauge)
When I'm on the highway, my temp gauge just climbsssss. The faster I go, the more the revs build up, the hotter it gets even with the heat on. The heat is basically fire.
When I'm idling, it'll stay right below the halfway mark.
what the heck is the deal? I left the rad cap off and the bleed screw off and let it idle for about 10mins with no problems and the heat on to let itself bleed through and it didn't overheat, but when i put the cap on and bleed screw on and drive normally it'll just heat up.
Thoughts?
Thoughts?
