Oxygen Sensor wiring?
  • lolcantturn
    • 4588
    Yo guys my o2 connector got stuck between my exhaust and the floor cause of my lowness:
    So i'm missing a connector, this is what I have left.
    i have a 4 wire O2 sensor, how do i wire this bitch up? My o2 is two white wires, one black, and one grey.
    Originally posted by TSI
    OEM+
  • 328ijunkie
    • May 2007
    • 3961
    Have fun. Its a pita. If you get it wrong it dont work.
    Check Us out on Facebook
    Full Product Line Tuning
    • lolcantturn
      • 4588
      Well it's only 4 wires. I don't think wedophones electrical troubleshooting told me much either.
      OEM+
      • MattM
        • Apr 2009
        • 931
        wires are all different colors are they not? yellow-yellow, black-black, etc?
        Full Build Thread Here
        • SkorcherX
          • Jun 2011
          • 267
          I am so glad you asked this, cause I am in the same boat. And I feel like I'm abusing the forums with questions as of lately. Subbed for the solution.
          • lolcantturn
            • 4588
            Wiring harness side = Yellow, brown, black, green
            O2 sensor side = white, white, grey, black
            Now I'm thinking, White and White can both be interchangable with Yellow and Green
            Grey goes to brown
            and black goes to black.
            need someone to confirm though.
            OEM+
            • ttrousdell
              • Nov 2009
              • 1770
              I wired my o2 sensor for my m30 swap. Took 2 o2s for m20 to get long o2 for m30. The two whites are interchangable. One is for heater but i cant remember what color it was. Look up wire diagrams for bosch o2.
              The Build:
              • pandaboo911
                • 2070
                Easiest way is for someone with a 4 wire sensor to pull back the boot on their connector and list which pin each color goes to.
                According to the diagrams:
                Pin 1: yellow
                Pin 2: black
                Pin 3: brown
                Pin 4: green
                Afaik the two white wires are for the sensor heater, and are interchangeable. Green would be power to the heater and brown the ground for it.
                Also what year is your e30, b/c the diagram states the green wire is actually green/blue, not solid green like your pic.
                • lolcantturn
                  • 4588
                  Good info! My wiring harness is from a 1992 E36 M50 Non vanos
                  OEM+
                    • 34844
                    why don't you go find the wiring diagram? it's all there. you can even get a new connector and pins and make it like new again.
                    • SkorcherX
                      • Jun 2011
                      • 267
                      ALL OF THE UPVOTES TO NANDO!!!!
                      Wait we can't upvote here?! Shit.
                      • drumad
                        • Aug 2009
                        • 1700
                        lol no upboats here
                        Speaking of which, I bought a new o2 sensor plug from blunt as I accidentally crushed my o2 sensor plug as well when I lowered the car.
                        I havent popped the pins out yet though and transferred them over.
                        I recommend either hacking a harness from a donor car or buying new pins and plug and rewiring.
                        2008 335i - n54b30
                        1991 318i - m52b28
                        1994 fzj80 - LAND CRUSHER
