CAlifornia BAR/SMOG/engine swap thread.
  • bradmer
    • May 2016
    • 389
    #226
    Originally posted by svn2002s
    Starting my OBD2 conversion (99 S52). Got a couple of questions regarding BAR requirements. When I got the engine I did not get any of the SAP stuff. So I don't know what I am missing yet and totally lost in this area. Hopefully that is the right diagram.
    Visit https://www.realoem.com/bmw/enUS/select?vin=LC89094 and punch in your vin for the right diagram.
    1- The TB has two inlets for coolant hoses, one coming from the head and the other from the metal pipe. Since I will remove the one attached at the head for the temp switch, is it ok to put a T on the other hose and feed both inlets to the TB?
    Yes, I put a T and it passed.
    2- Keep the Secondary air injection pump and SAP from the S52 all the way to the intake manifold (Pump, electronic switch and valve). Just the way it comes on the s52.
    Yes
    3- Where does the intake hose (suction hose per realoem) goes. Don't see any inlets in the intake manifold.
    ICV under intake IIRC, clean ICV prior to install.
    Trunk mounted evap.
    Good luck
    • herbie
      • Jan 2011
      • 206
      #227
      Sorry, wrong thread. this is M50/52, please disregard.
      Hi guys,
      So I am in the process of trying to make my M20B25 swapped early 318i BAR'd. Currently, it is running on Bosch 380 and naturally, it doesn't have a Check engine light.
      1.) Would swapping a 173 DME allow me to be able to read codes via the C101 connector and not just through the stomp test? In case it is required for smog.
      2.) How do I go about adding a check engine light? from research, it's installing a light and wiring the hot to a switched 12v and grounding it to the DME. Can I simply tap into the wire the connects to the DME? if so, which wire? is it the gray wire?
      Thanks in advance
      • raj
        • Oct 2013
        • 100
        #228
        I went back to the ref today… and left with a sticker! Notes from the second time around:
        - I was failing before for very high HC and slightly over max NOX.
        - Since the last time, I replaced the cats with new Walker CalCats, cleaned the MAF, and replaced the plugs.
        - I still was close to the max on HC (78/93)
        - The referee was the same one who inspected the car previously. Since nothing changed, the visual inspection went a lot faster, but he did check.
        - I ran the car HARD before I showed up (multiple high RPM pulls), and he put it on the rollers pretty soon after my arrival. I think this was a contributing factor last time, since the car sat for 30+ minutes while they got set up. This time it was more like 20, and most of that time it was idling.
        - They install the sticker in a permanent location on the body. He originally went for the engine bay, but I preferred the passenger's door jamb, so he obliged.
        Next I need to get plates, but the hard part is done! Super relieved this process is over with.
        • bradmer
          • May 2016
          • 389
          #229
          Congratulations raj! Great job!
          Would you mind posting the chassis and motor details of your swap?
          Thank you!
          • raj
            • Oct 2013
            • 100
            #230
            Thank you!
            Sure thing…
            Chassis: 87 325iS
            Motor: S50 US. Stock headers and mid pipe. New Walker cats. 21.5lb injectors, stock MAF, TRM tune. Castro airbox.
            • Sean S.
              • Aug 2012
              • 196
              #231
              At the smog ref right now. Is it normal for them to refuse to let you watch what they are doing? I mean, I sort of get it; don't want to give any secrets away [emoji38], but I can't even be in the vicinity of the car?
              Sent from my SM-G960U using Tapatalk
              • raj
                • Oct 2013
                • 100
                #232
                I was allowed to watch and even fielded questions the first time. The second time I was asked to sit outside the bay with the rollers but could still watch.
                • Sean S.
                  • Aug 2012
                  • 196
                  #233
                  Well, technically, I passed ... But even after supplying the title to the donor car and showing the inspector that the VINs all match, I still have to go get a letter from a BMW dealership stating that the ECU has not been altered.
                  So close, but no BAR sticker!
                  • Sean S.
                    • Aug 2012
                    • 196
                    #234
                    Finally!
                    • fastestbox
                      • Jul 2018
                      • 124
                      #235
                      What airbox are you OBDII guys running to pass BAR? The Z3 one I have doesn't seem to fit at all and I really don't want to move the ABS module. I know there's CARB certified airboxes for e36 that may work, but since I'm BARing mine as a Z3, I don't believe I can use them.
                      91 318iS - aluminum M52B28 + ZF320 + 3.15 Torsen
                      • bradmer
                        • May 2016
                        • 389
                        #236
                        Rogue Engineering sells it,
                        http://www.rogueengineering.com/
                        ECIS-INT1998-2000 M Coupe/Roadster ECIS Cold Air Intake
                        I have a Z3M motor in my 87, I am close to passing and have had this CAI already approved by the ref. Comes with a sticker and heat shield you need to customize.
                        • Sean S.
                          • Aug 2012
                          • 196
                          #237
                          I used a KnN e36 conical filter attached directly to the AFM from the s52. Gotta have the CARB sticker or you will not pass. I printed the exact reference description for the applicable CARB number as well so the ref didn't have to go looking (and potentially get wrong info). Once he verified the sticker number applied to the year of engine, he didn't really say anything else about it. Sent from my SM-G960U using Tapatalk
                          • e30devo
                            • Aug 2005
                            • 1102
                            #238
                            Thanks for the info from all previous posters.
                            I found myself wondering what different engines failure limits were, ended up finding the page here. Might be helpful in knowing before testing. https://www.bar.ca.gov/pubwebquery/c....aspx?make=BMW
                            ASM 5015 is the 15 mph test, ASM 2525 is the 25 mph test. I matched these to previous posts to verify they are correct, so thanks to those that posted their FAIL/PASS slips!
                            I'll be trying to pass an OBD2 S52, with all emissions equip...
                            • hambone64
                              • Apr 2020
                              • 2
                              #239
                              Hey guys,
                              First post here. I've been doing research trying to find answers around the exhaust. I'm in the process of doing a OBD1 S50 swap and got all original engine, ecu, headers and midpipe from the person who sold me the engine.
                              My question is, can the midpipe be modified at all if I reuse the 2 stock cats? If not, then how are you guys fitting the midpipe. Mine hits both the sway bar and the lollipop.
                              • mtech325
                                • May 2008
                                • 569
                                #240
                                Originally posted by hambone64
                                Hey guys,
                                An exhaust shop can modify the downpipes of the e36 midsection for better clearance (I did this with my first m50 swap and it passed BAR), but I'd check with the referee station you're planning on using first. Some referees are more lenient where a full custom exhaust that matches the stock e36 configuration is acceptable, while others are more strict and require a completely unmodified midsection.
                                If you want to make the unmodified midsection work, you'll have to use the offset "eyeball" arm control arm brackets and clearance the subframe as shown here.
