Lira (euro DS mtech II 318is reshelled, 24v swapped, also now BAR'd)
  • kronus
    • Apr 2008
    • 13032
    #106
    so it runs.
    and throws the same 1221 code as before :[
    additionally now it throws a 1222 code. I am suspecting the fuel tank vapor system.
    cars beep boop
    • kronus
      • Apr 2008
      • 13032
      #107
      it was the fuel tank vapor system
      now i'm fixing it
      cars beep boop
      • pandaboo911
        • 2070
        #108
        You didn't get a code for purge valve? I think it's 1263, won't trip a light but it'll be stored.
        • kronus
          • Apr 2008
          • 13032
          #109
          I'm on CEL flashing pleb status, didn't see any 1263s.
          also
          FIXED mostly
          this is embarassing, but, uh, don't forget the o-ring between the master cylinder and brake booster.
          there is still a evap system issue but i've worked around it for now and car should be BAR-able.
          cars beep boop
          • deutschman
            • May 2008
            • 5958
            #110
            God its nice. Good work man.
            • e30serg
              • Dec 2006
              • 562
              #111
              Where's your shop located?? Would love to see this in person...
              • kronus
                • Apr 2008
                • 13032
                #112
                we're in Belmont, and having an open house/car meet sometime in March. I'll post more info as it comes up.
                yesterday I took off the old/new exhaust, and started modifying things to get the unmodified E36 M3 downpipes on, to make absolutely sure that I would pass BAR.
                after a bunch of heating and hammering, they bolted up!
                to avoid pulling the manifolds to get swing clearance I had to use my patented Kronus Clearance-O-Matic Device:
                the downpipes do sit several inches lower than I'd like, but that's ok, they're not on here for long..
                I then borrowed a friend's E36 UUC Corsa exhaust and tossed it on. So, myth confirmed, a fully unmofied E36 exhaust can fit on an E30 24v swap!
                it, uh, sits goofy to clear the rear valence. It can be mounted straight, but the pipes don't exit where the Mtech valence hole is.
                then, I drove it to the referee station, sailed through the test and got my sticker. easy!
                cars beep boop
                • iwantspeed
                  • 3164
                  #113
                  Congrats on passing the bar.
                  It doesn't need to look pretty just legal
                  Project
                  Parts for Sale
                  Feedback
                  YouTube Channel
                  • RCM3
                    • Aug 2011
                    • 1304
                    #114
                    Nicely done, beautiful E30.
                    -Ryan
                    05/87 Henna M3
                    04/71 Baikal 2002tii
                    • Javier h
                      • Sep 2007
                      • 1189
                      #115
                      Congrats.
                      • 2002jm
                        • Sep 2005
                        • 2077
                        #116
                        good deal
                        Good deal on the car and the smog. California smog is a big deal! Your car looks so good!
                        jm
                        • rzerob
                          • Jun 2013
                          • 2315
                          #117
                          Congratulations. Now lets see it in it's rightful form.
                          • kronus
                            • Apr 2008
                            • 13032
                            #118
                            thanks folks!
                            as soon as I figure out which part of the camera to point at the enemy!
                            (but the not-E36 exhaust is back on already. :mrgreen:)
                            cars beep boop
                            • e30serg
                              • Dec 2006
                              • 562
                              #119
                              Awesome!!
                              • Dagamus(NM)
                                • 621
                                #120
                                Nicely done Kronus.
                                Gun control means using both hands
                                Sex, Drugs, Rock 'n roll. Pick two.
