Low clearance oil pan, built
  • bmw2002tiiagave
    • 501
    awesome idea. you can always retro fit an oil cooler if you need cooling at a track day.
    1972 2002Tii
    • Jim Lepage
      • Jul 2008
      • 1138
      Nice, I need one like that !
      I'm in for installed pics !
      E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
      • Jalves619
        • 596
        I've been thinking about doing this as well but adding a kick out on the side of the sump to allow a bit more oil capacity. Awesome work.
        • karlorado
          • Jan 2011
          • 264
          Not my car, unless avery0829 puts one up I probably wont be taking one sorry.
          • karlorado
            • Jan 2011
            • 264
            Originally posted by Jalves619
            Awesome work.
            thanks! I appreciate it
            • sticksdaman
              • Apr 2005
              • 2987
              subscribed, id also be interested in seeing what this would run me.
              Originally posted by ebelements
              Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
              • trackjunkie21
                • Jan 2010
                • 3962
                I would, but that would be when I pull the motor for the stroker:p
                Originally posted by Wh33lhop
                VANOS: sometimes you just need to go full retard.
                • TinyT
                  • Jan 2011
                  • 152
                  Looks pretty good, the only thing that worries me besides the capacity is the ground down welds. Aluminum doesn't penetrate like steel and the strength comes from the filler, unless that thing is fully welded on the inside Id be worried about the strength of the new piece.
                  • karlorado
                    • Jan 2011
                    • 264
                    In total there is 2 passes on the outside and one pass on the inside, then the sealer over the inside weld.
                    • TinyT
                      • Jan 2011
                      • 152
                      good deal, should be money!
                        • 37829
                        Very cool, nice work man!
                        Classic BMW Specialists
                        Grover Beach, CA
                        www.BimmerHeads.com
                        • dnick
                          • Apr 2011
                          • 1377
                          lets see installed pics
                          • karlorado
                            • Jan 2011
                            • 264
                            Not for my car and I don't see it all that often anymore, it would be up to him to take some and put them up.
                            • karlorado
                              • Jan 2011
                              • 264
                              Installed and running daily now.
                              • JGood
                                • Jan 2004
                                • 7959
                                ^lol
                                e30 restoration and V8 swap
                                24 Hours of Lemons e30 build
