Low clearance oil pan, built
  • karlorado
    • Jan 2011
    • 264
    So, a friend of mine completed his 24v swap almost a year ago now and has been daily driving it ever since. As just about all of you know the oil pans hang pretty low and combined with an adjustable suspension the 'low file' can take its toll on said oil pan. With constant banging of the streets and tired of removing Recaro from ass cracks we decided to take action on this issue that comes hand in hand with the evolving mod-crazy mentality we share. After breaking through yet another oil pan I took it upon myself to help a friend out and relieve some of the typical worries associated with this particular issue at hand.
    First I took a good look at the replacement oil pan and decided to remove just about 1 1/4 inch total material after marking it out and choosing a good line.
    After opening it up a template was fashioned out of cardboard to finalize the overall shape to ensure a precise fit.
    The next step was to transfer the template to sheet aluminum (street sign) twice, one as the new pan bottom and the second as a cover (drilled just for fun).
    With the new bottom welded on I smoothed down all the welds, fitted the cover piece so it was tight and uniform, welded it on and smoothed the welds down once again.
    Once fully welded and the inside seam sealed just as an added precaution, a blangin' coat of metallic gold was applied just for fun (the only paint left in the cabinet too but whatever).
    This is just one of the little things I do to help out friends in need and keep my jittery hands busy. He's happy and going down the road worry free once again.
    Notes: The inner seam around the bottom of the pan was seamed with a 2 part aluminum epoxy that is made specifically for the Navy for use in oil tanks in seagoing vessels, just as piece of mind against any leaks. A new drain plug location was located then drilled and tapped. The old pump pick up tube was shortened as well, sorry no pictures of that were taken. As you'll notice the prevision for the oil level sensor have been removed, in this case the sensor wiring has been looped so that light does not turn on. The dipstick tube was also shortened and the dipstick itself renotched once the correct amount of has been added back into the engine. I personally would recommend adding an oil cooler so that the overall amount oil is maintained in the system.
    I hope this writeup is somewhat interesting to you all or at least worth a good laugh if you didn't like it. If you would also like to have your 24v swap oil pan (or M20 pan) shortened please contact me via PM for details thanks.
  • AndrewBird
    The Mad Scientist
    • 11898
    Looks good. The only issue I see is the amount of oil capacity lost due to cutting the pan. Should be fine on a street car, but probably wouldn't be the best on a track car.
    • Jafxod
      • May 2011
      • 1301
      I appluad your hard work and determination to fight back on the shittyness of low 24v e30 pans. Ive been through 3 m50 pans WITH a skidplate, it blows. I was almost as low with my m20 and never even scratched my pan.
      But like said i would be concerned for track use, but then again low is never really an issue on the track.
      • reelizmpro
        • 9553
        Cheesegrater?...for maximum roadkill carnage.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • karlorado
          • Jan 2011
          • 264
          The amount displaced is just less than a full quart, but as you stated in a street car this will have little to no effect.
          Thanks for taking a look and liking my 'bored time'. Long story short I'm a big advocate against skid plates, thus mods like this and raised engines/ drivetrains.
          • Cronopoulos
            • Jul 2011
            • 2187
            Very cool idea.
            Project log -- DIRTY 30
            2.7i * Megasquirt tuned * E85 powered
            • lolcantturn
              • 4588
              With the motor raised up all the way and the pan cut, is the subframe/steering rack/front valance now the lowest point of the car? cause i'll sell my skid plate in a hurry and send you my pan if it is.
              Originally posted by TSI
              OEM+
              • karlorado
                • Jan 2011
                • 264
                His motor isn't raised but just with this pan the steering rack bolts are now the lowest point, he's running an 'i' lip as well.
                • lolcantturn
                  • 4588
                  so the use of a skid plate is now rendered useless isn't it?
                  I get so jealous of my friends with lowered E36 M3's or my friend's S14 who's lower to the floor than me but yet he goes over every road as if it's nothing. I want to be able to do that.
                  can you send me a PM of a job quote for this? I will be selling my peerless plate (Sorry peerless, it is an amazing product after all!)
                  OEM+
                  • avery0829
                    • Dec 2008
                    • 793
                    • karlorado
                      • Jan 2011
                      • 264
                      Yeah sure, get at me any time.
                      Originally posted by avery0829
                      This pan is the TRUF, I'll post a picture of being a litle higher than level with the steering rack.
                      I'm happy this worked outed out Eric! Gotta get a proper motor in my car so I can do it for myself too
                      • accident
                        • 7303
                        that's pretty badass
                        Moral of this story?
                        • yazansoft
                          • Jun 2011
                          • 22
                          im using e34 m50 motor mount "i think its taller about 1/2 inch than e28 one" and 215 / 45/ 17 tire, its very good clearance.
                          • Wishno87
                            • 6025
                            I used to have those too but they are much too soft.
                            • LuckyHenriksen
                              • Jun 2010
                              • 4244
                              Cool idea. PM'd
                              Bahama Beige E23 Project
                              Bluebird Bus Conversion
                              New Oregon Trail
