i combed through past threads digging for an answer and honestly couldnt find a clear cut one, so my apologies if i missed it in my searches.
my m52 swapped car is running a 5spd ZF transmission and currently has an e36 slave in it (part # 1159045). the clutch will grab just off the floor when releasing the clutch pedal. probably every other time you press the clutch pedal down it makes a noise in trans area before the pedal is totally depressed, possibly being that the slave cylinder is running out of room/pushing the pressure plate too far.
does anyone have a part number or recommendation for the correct slave cylinder to use?
