Cali ref question (finally passed)
  • smooth
    • Apr 2005
    • 1940
    I want to put the newest diesel BMW makes in mine eventually. But I'm having difficulty finding out how likely that would be in passing here.
    If I understand what I've been reading, the engine has to be from like you said a same year car or newer but it also has to be offered in the US. And then we don't get the diesel options here in the US. But we are starting to or might in the future? That's what I think I've been reading.
    Das ist nicht nur nicht richtig, es ist nicht einmal falsch!
    • Highway1
      • Jan 2009
      • 773
      Well I Just got back from the ref. I have oem cats in and they still spent about 15 minutes looking at the cat to make sure it was the right one. After the full test I FAILED emissions at 15mph. HC was 185 (108 Max) and NO was 1348 (767 max).. so now i'm looking at another $500 for new cats! :hitler: FML...
      • jrdeamicis
        • Nov 2008
        • 956
        You need to measure your pre and post cat temp to verify that they are working..
        Past Car : E30 S50 6 Speed 5 Lug 3.73
        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
        ___________________________________________
        BNB Designs
        Engine Swaps, Fabrication, Innovation, General Repair
        Richmond CA
        Julian 848-248-8029
        • Highway1
          • Jan 2009
          • 773
          I passed fine two months ago with my single cat. Nothing has changed except for the Cats and O2 Sensor and the O2 sensor shouldn't really effect Nox.
          • Highway1
            • Jan 2009
            • 773
            First one was with single cat second was with oem dual cats and different 02 sensor
            • rlddlr53
              • Oct 2009
              • 1450
              cats you bought were prob worse than your single. go to http://www.maxautosupplies.com/
              Thats where I bought the cats for my swap. Cal legal ones ran me 70 each I believe. I put new plugs, new oil, and ran turner software and it passed very clean.
              Wonder what tune you are running
              • S62
                • Nov 2011
                • 262
                I would check Pick n Pull for an e36 cat.
                • Highway1
                  • Jan 2009
                  • 773
                  Spent $340 for new cats and Fucking killed it! Wohoo!
                  • firefirefire90
                    • 163
                    sweet! Good deal dude! Is it possible to get intake modifications like ITB's bar-legal?
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      ^No.
                      • Robert
                        • Dec 2010
                        • 3770
                        any pics of the motor setup & cat set up ?
                        trying to pass bar at the moment too, just spent $150 on two cats . CATCO Brand.
                        • 2mAn
                          SeƱior Mod
                          • 21015
                          from my experience the cats are always removed once the car gets to the JY
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          Make R3V Great Again -2020
                          • isra
                            • 177
                            What cats did you buy
                              • 37833
                              Robert, you better make sure they are CA cats or you're fucked.
                              Grover Beach, California
                              BimmerHeads.com
                              • hwy84
                                • Aug 2009
                                • 190
                                ^ This.
                                ...and I bet they aren't. Use the tool here: https://ssl.arb.ca.gov/PartsSearchTo...earchTool.aspx to see if the cats you are buying have an EO number, otherwise you are throwing money down the drain.
                                Current:
                                1991 325i Sedan - S50 Swap
                                1988 325i Cabrio
                                Past:
                                1991 M3
                                1991 318is
                                1985 325e
