M50nv stroker build. Question about rotating assembly combo.
  • blink977
    • Jun 2010
    • 24
    Originally posted by 328ijunkie
    Bore and stroke on the S54 are completely different than the S52. And the only cranks you listed that are the same are the M54 and S52. All the others are different.
    what is bore and stroke of S54? I can't find any technical info on this engine.
    also maybe someone knows S54 rod length and piston compression height?
    • trackjunkie21
      • Jan 2010
      • 3962
      There was a guy that dropped the m54 rotating assembly into the m50 with some reground cams and a tune made 219whp, you can get the assembly for around $600
      Originally posted by Wh33lhop
      VANOS: sometimes you just need to go full retard.
      • Wanganstyle
        • 2828
        11.5:1 compression. Cnc reliefs in pistons to clear 60 degrees of double vanos.
        Stroke is 91.0
        Rods are 139mm
        Pistons are 87.0 bore
        S54 iron block is ~20mm taller than a pedestrian m50/s52 block.
        • blink977
          • Jun 2010
          • 24
          Stroke is 91.0
          Rods are 139mm
          I don't think it will be 20mm taller, 2mm is closer to truth. Anyway great info, but what about piston compression height? can anyone figure this out?
          • Wanganstyle
            • 2828
            TRY IT YOURSELF :D
            the S54 deck is Literally 20mm taller. My S54b32 is on a engine stand right now, I fit up the lower timing cover from a S52b32 on the engine stand next to it, and it is ~20mm short. the crankshaft and lower cover mounting points are almost identical besides for the waterpump casting on the iron block, and the s54 deck looks literally extended 20mm TALLER on the top of the deck.
            many honda engines are stroker deck engines -b16/b18/b20. the Deck actually gets taller to allow for a stroker crankshaft to function.
            those thinking a S54b32 rotating assembly can be easily crammed into a M50 are dreaming. If you want a S54, buy an S54 :D
            at TDC the S54 rotating assembly pistons would be 20mm out of the block lol (if crank can evenclear a s52 bottom end).
            the bore is also 87.0mm, the camshaft chain drive is double and chain length longer than m50 family........Does this sound compatible at all???
            • blink977
              • Jun 2010
              • 24
              If you have it on a stand, can you measure piston? from the center of the wrist pin to top of piston. It will be good info cause I can't find tech data of S54 pistons.
              • Wanganstyle
                • 2828
                The pistons are out of the block, have not installed anything besides the crank (just plastigauged).
                I can take some photos of it with my digital caliper in mm, can you post a photo of how you want me to measure it?
                Would you like me to measure the rods also?
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5223
                  measure from the edge of the wrist pin hole to the face of the piston and then add half of the hole's diameter.
                  Originally posted by priapism
                  Originally posted by shameson
                  • blink977
                    • Jun 2010
                    • 24
                    and yes, please measure the rod form big end centre to small end centre and also wrist pin length and diameter. tanks
                    • aplinweiss_is
                      • Jun 2011
                      • 89
                      Hijacking my thread back a second,
                      Anyone familiar with the M54 internals.
                      The B25 and B30 both have the same bore, different stroke. But the part numbers are not the same for the pistons, not sure about the rods.
                      I'm trying to figure out if I locate a M54B30 crank could I use the B25 piston and rods in
                      my M50 to create the 3.0L stroker?
                      • trackjunkie21
                        • Jan 2010
                        • 3962
                        the b30 pistons have the wrist pin placed higher because of the increased stroke, I would go with the whole b30 assembly.
                        • samurai7
                          • 428
                          And the measurement was??
                          Originally posted by nervousmini
                          Break My Wallet
                          Bring My Wallet
                          Bring Money With
                          and the M cars are a multiplier
                          regular repair Money * 3 = M3
                          regular repair Money * 5 = M5
                          regular repair Money * 6 = M6
