Swapping Gauge Cluster Parts?
  • SkorcherX
    • Jun 2011
    • 267
    Is it possible to swap the 7K tach from a 325i cluster into a 325e cluster? In order to replace the existing 4.5K tach?
    I just bought a 325i cluster and it appears to be in disrepair. Numerous bulbs missing, one of the mounting tabs is broken, fastening nut missing, clear plastic is no longer glued.
    I think my older 325e cluster is in much better shape, but I really want a 7k tach. I have seen the DIY on painting the needles, and installing the gauge rings, but I haven't seen any transplant surgery documented.
    Any information on this would be greatly appreciated, and pictures are always welcome.
    Thanks!
    • 34839
    doesn't work without the 325i coding plug, and it won't work on an early 325e cluster at all.
    if your cluster has the newer style coding plug, you could swap just the gauge face and coding plugs (leaving your existing tach motor/needle). the tach itself is the same, it's just the face and coding plug that are different.
    • BusyMrE30
      • Feb 2011
      • 55
      i need help here to i have a 84 325e and did the m50 vanos swap with zf tranny but purchased a cluster to put in and it dosent work what do i have to do to the 325e stock cluster to rev to 7. i also purchased i believe its an i or an is cluster what needs to be done any advice would help me and skorchex a lot thanks
      • Jean
        • 18228
        Easy thing to do would be to install a 325i cluster and transfer your fuel gauge from the original cluster that came in YOUR car (to match the fuel tank).
        • Adrian_Visser
          • Jun 2006
          • 2823
          The tachs have different pins on the late model motometer and vdo clusters, the speedos can go in either manufacturer's cluster though. I tried making honey out of dogshit with two clusters and found that out.
          '89 Alpine S52 with goodies
            • 34839
            you don't need the whole motor - just the gauge face.
