S52 swap won't start!?
  • Supadave
    • 1006
    I checked my wiring multiple times, I'm pretty sure that's not were the problem is. Today I'm going to try another ecu and see if that helps.
    Is there somthing else I should be doing?
    https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
    • 328ijunkie
      • May 2007
      • 3961
      check your wiring.
      Check Us out on Facebook
      Full Product Line Tuning
      • SwiftE30
        • Jun 2010
        • 998
        Originally posted by sohc12vm20
        I know it sounds dumb, but I had no fuel and spark, turns out i forgot to hook up the main power sorce cable from harness..
        i did this exact same thing too! Spent hours and hours searching on here trying to figure out my problem, checking and rechecking things. My main power cable to the harness was covered in a black wire cover so i thought it was ground.
        is your CEL on when your ignition is in the ON position If not, your ECU is not getting power. if your confident in your wiring just start checking power from the battery throughout the harness and go till you find your problem.
        1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
        • Supadave
          • 1006
          Ok guys found the problem, I put the chip in upside down, flip it and it started!
          • Den_k321
            • 1248
            lol, always something stupid!!
            nice man!!
            1988 325is S50 in-progress.
            http://www.facebook.com/E30LocalCrew
            Few pictures:
            http://www.r3vlimited.com/board/showthread.php?t=255061
            • SpeedRacer85
              • Jul 2011
              • 424
              Its alive!!!!
              • LJ851
                • 7918
                Where's the videos, Dave?
                Lorin
                The M30 is God's engine.
                • SwiftE30
                  • Jun 2010
                  • 998
                  haha glad its something simple. Nice work.
                  • ian e30 318is
                    • Mar 2007
                    • 1809
                    Originally posted by 328ijunkie
                    How is the C101 wired. Im betting there is your problem.
                    This was my problem...one of the pins was in the wrong location. Starter pin if I recall correctly. Changed it and fired up fine. Glad it fired!
                    1991 LS1 Swapped 318is
                    Instagram:
                    https://instagram.com/saltybeast/
                    LS Build Thread:
                    https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                    • DREWHALL
                      • Feb 2006
                      • 1207
                      The main relay on mine took a poop, just another thing to keep in mind for everyone. It's the white relay on the engine harness.
                      • dnick
                        • Apr 2011
                        • 1377
                        congrats!! waiting for videos now :)
                        • Supadave
                          • 1006
                          Videos coming soon, I need a new clutch lol
                          • SwiftE30
                            • Jun 2010
                            • 998
                            what are you going to go with?
                            • Supadave
                              • 1006
                              Bad news guys, I just put in my new clutch and the dam thing want turn over?? maybe starter went out? I check all the wires on the starter and there still hooked up, it started fine before I drop the transmission.
                              Might skip work to figure this out ahhhhhh!
                              • SwiftE30
                                • Jun 2010
                                • 998
                                WHat is it doing? Not doing anything/just making a little clicking sound when you turn your key/ or trying to turn over but wont fire up?
                                Did you make sure you got the gears lined up when you put it back in?
