S52 swap won't start!?
  • Supadave
    • 1006
    I need your help, I have a 91 318is with a s52 obd1 swap. I'm using a e34 wire harness and everything is wired correctly. Engine turns over fine, but there is no fuel coming to the fuel rail. I have already checked the fuses and relay, everything is fine. But I'm not getting any power to the fuel pump?
    Any suggestions?
    https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
  • jrdeamicis
    • Nov 2008
    • 956
    Are you getting spark?
    Past Car : E30 S50 6 Speed 5 Lug 3.73
    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
    ___________________________________________
    BNB Designs
    Engine Swaps, Fabrication, Innovation, General Repair
    Richmond CA
    Julian 848-248-8029
    • Supadave
      • 1006
      I haven't check for spark, I'll check in the morning... Im starting to wonder if it's the AA chip I have.
      • Danny
        • 14216
        Are your fuel hoses on correctly? Have you verified the pump is not turning on with a multimeter?
        • bernzpeed
          • 3917
          My bet is the fuel hose.
          89 E30 S52
          Transaction Feedback.
          • Supadave
            • 1006
            Ok, no fuel and no spark. And I checked the fuel pump with a multi meter and nothing.
            • jrdeamicis
              • Nov 2008
              • 956
              CEL in the run position?
              BNB Designs
              Richmond CA
              Julian 848-248-8029
              • Supadave
                • 1006
                Cel? What is it and can u explain?
                • Supadave
                  • 1006
                  Help
                  • STAGGERED M3
                    • Oct 2009
                    • 368
                    CEL = CHECK ENGINE LIGHT
                    and you need to find out why there's no power to the fuel pump.
                    • Supadave
                      • 1006
                      Yes the check engine light is on. Still no fuel or spark, do u guys think it's the ecu?
                      • hoveringuy
                        • Dec 2005
                        • 2750
                        It won't power the pump until it senses engine rotation from the crank position sensor. Also, do you have a silver label DME?
                        • sohc12vm20
                          • Jan 2010
                          • 688
                          I know it sounds dumb, but I had no fuel and spark, turns out i forgot to hook up the main power sorce cable from harness..
                          • Supadave
                            • 1006
                            I have a red label 413 with AA stage 2 chip
                            • 328ijunkie
                              • May 2007
                              • 3961
                              How is the C101 wired. Im betting there is your problem.
                              Check Us out on Facebook
                              Full Product Line Tuning
