California Bar Questions
  • red_e30
    • Dec 2010
    • 242
    was it hard to bar your swap did you have to do alot of stuff
    my build thread:http://www.r3vlimited.com/board/showthread.php?t=232324
    • ian e30 318is
      • Mar 2007
      • 1809
      It was extremely easy for me. The miramar college bar station was really chill! But I did do quite a bit to make it through this easy. I have an obdI s50, stock ceramic coated exhaust manifolds, stock ecu with a delete chip, two brand spankin new e36 cats, and the stock e36 o2 sensor location. The only thing I was really worried about was my K&N cone filter which they didn't say anything about. Other than that it was pretty straight forward. I had no problem with smog on it since the whole top end was rebuilt and most of the swap was new. If you have any questions feel free to ask me.
      -Ian
      P.S I like your build thread! and I heard sacramento is fairly easy to pass the bar
      1991 LS1 Swapped 318is
      Instagram:
      https://instagram.com/saltybeast/
      LS Build Thread:
      https://www.r3vlimited.com/board/for...s-e30-ls1-swap
      • red_e30
        • Dec 2010
        • 242
        ^thanks for the reply going to have to bar my swap also
        did you have your evap canister hooked up or you don't need that to pass
          • 37833
          You most definitely need the EVAP hooked up. That's smog equipment.
          Grover Beach, California
          BimmerHeads.com
          • Dozyproductions
            • Jan 2007
            • 4682
            Congrats Ian! Now you're fully legal to do burnouts in front of cops!
            • red_e30
              • Dec 2010
              • 242
              yea pretty much knew that just to confirm thanks :up:
              • Jcate30
                • Dec 2013
                • 12
                question if anyone can help me out it would be much appreciated. Im trying to bar my swap. Three things i keep failing in. My VSS reads at 18 mph at all times, they also want me to provide documentation on the right ECU and flash but haven't told me which one to get. What am i missing?
                • 2mAn
                  SeƱior Mod
                  • 20982
                  Originally posted by ian e30 318is
                  Guess what...my bitch is legal!!! I breezed through the Miramar station! Very friendly as well
                  dude that is SO awesome, congrats!! (jus noticed this is 2+ years old lol)
                  Im tempted to do this soon, Im just sketched out because Im running an OBD1 M52 and have a few OBD2 parts on the car still. Main smog stuff is there though, S52 exhaust manifolds (with SAI ports welded up) , S50 downpipe, stock cats.
                  I know I need to wire up the CEL though, and I dont have a charcoal canister on my car.
                  Did they check those?
                  Simon
                  Current Cars:
                  -1966 Blue Boat
                  -1969 Red VW
                  -1986 White BMW
                  -2006 Green Thing
                  Make R3V Great Again -2020
                  • blackhawkimpact
                    • 2415
                    -Ian
                    New e36 OEM cats?
                    • E30_pilot
                      • Sep 2005
                      • 1461
                      I used aftermarket cats, BUT you have to get the ones that say "California approved" ones.
                      -Frank
                      1987 325is m50nv (schwarz)
                      1990 325is (sterling silber)(sold)
                      2001 525i
                      • jstam
                        • Jul 2010
                        • 48
                        any examples of a CEL setup? Did you just put one in the center console somewhere or on the dash? This was the one visual inspection item I did not pass.
                        also, any experience w/ really high NOX readings at 15 mph (>2200 vs. 650 for passing) and high HC's? S50 OBD1, M50 intake, Dinan CAI, stock exhaust and new cats, not sure which chip I am running - need to check. Car runs hot b/c I probably need to bleed the system (m44 rad, Stewart H20 pump, etc.). Any suggestions where to start w/ this?
                        1985 325e, 74k miles (S52 w/ OBD1, Bistein Sports, H&R Sports, IE sways, 3.23 LSD, TD 15x7/Star Specs, Euro bumper conversion)
                        1998 M3 (4dr, 5sp, TCKline) (sold)
                        2002 325i (sold)
                        2009 X5 3.0si
                        • e30user
                          • 36
                          I have an M3, which doesn't have the Check Engine light in the cluster, or I would have tried using that. Instead, I just get a red LED bulb and mounted it to one of the blank covers next to the hazard and rear defrost buttons. I used a label maker to make a hideous "CHECK ENGINE" sticker. It's pretty basic but worked, and was good enough for the inspector. Basically, my S50 experience was very much like Ian's.
                          • jstam
                            • Jul 2010
                            • 48
                            thx e30user - the referee said any light/label combo would work, as long as it was functioning. I may put mine on the center console where I put my gauges (aftermarket, in the blank area in front of the ash tray).
                            2002 325i (sold)
                            2009 X5 3.0si
                            • 2mAn
                              SeƱior Mod
                              • 20982
                              I wanted to make a label that said "oh shit" or something, or maybe just a skull & crossbones or something stupid... not sure if they would appreciate my humor :rofl:
                              Simon
                              Current Cars:
                              -1966 Blue Boat
                              -1969 Red VW
                              -1986 White BMW
                              -2006 Green Thing
